Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 113
Thread: Steering Shake.
  1. #91
    Advanced peterbr1's Avatar
    Apr 2015
    Melbourne western subs
    cmon kids get to de chowper
  2. #92
    22 Post(s)
    Quote Originally Posted by peterbr1 View Post
    LOL this my show go get your own go on now git
    Your show... that's right I clearly didn't realise, sorry for entering the thread and raining on your parade
    96 GQ coil/Cab
    08 G6eT
  3. #93
    Redlands, Queensland
    Wow, this escalated quickly. Is this normal for this forum?
    peterbr1, I won't have time to pull the shims before the wheel balance. If that fixes the problem (and I'm not expecting it to) then I won't have to do it.
    BillsGU, I'm going to Bob Jane's who do 4WD tyres, so I'll have a word to them about making sure the balance is done on the right machine. Thanks for the tip.
    Ben-e-boy, I'll get the tyre guys to check the castor (I incorrectly called it the camber in my last post). Thanks for the tip, also.
    However, as I said in my opening post, the dire warnings ("...just adds preload on the bearing, it's a bandaid fix...") are what I hear from a variety of people, but I have yet to learn of a single person who has actually had problems caused by removal of the shims. The amount of people who must have done this fix should have resulted in at least one or two reported failures. I'm trying to hear about them.
    Please be aware that I'm not trying to be antagonistic. Warnings are cool: I like them. They mean I can assess a risk. But if that risk has no evidence of occurring then the warning is ultimately one that has a very low, or even zero, priority. This is a standard risk assessment outcome, if you've ever needed to do this sort of thing.
  4. #94
    Quote Originally Posted by PullsyJr View Post
    No mate it is not normal
  5. The Following User Says Thank You to Winnie For This Useful Post:
    mudski (6th November 2015)
  6. #95
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    No but it's heaps of fun.
  7. The Following User Says Thank You to 4bye4 For This Useful Post:
  8. #96
    Ok, fair enough. Crawling through the forums I'm not seeing this sort of... ahem... banter all that much. But like everywhere on the internet it's hard to tell.
  9. #97
    SHELLHARBOUR
    Hi
    Just removed the shims from my 2010 Patrol
    no shake for the first 60,000km
    But fitted new tyres and it started, put the old rims and tyres back on and still there?
    So did caster correction bushes greased &adjusted wheel bearings, new shock new steering damper Wheel alignment and Caster check all ok but shimmy still there.
    So lifted front end and placed on stands removed wheels.
    checked resistance full lock to full lock.
    water blasted off all the muck, then loosened all crews for the king pin bearing carriers
    Placed jack under the hub and slight nip removed lowwer bearing inspected and greased then removed shimm and refitted
    same for top bearing tested lock to lock and no difference.
    Whilst inspecting noticed the top L/H bearing had grease acoross the bearing load surface all others shiny
    Test drive and shimmy gone
    So will plan to re grease and re test every 20,000 km from now on
    Happy with result
    regards
    Joe
    2010-DX Patrol Dual Cab Chassis, Front LOKKA, 3500kg GVM, 4.8 front brakes! (now stops like it should!), 4.625 Diffs (now drives like it should) 35"Mud tires, 3"exhaust, Rear air bags
  10. The Following User Says Thank You to JoeG For This Useful Post:
    the evil twin (6th November 2015)
  11. #98
    Apr 2015
    Apology accepted good boy ben-e Oh I was only kidding............about the show thing it was aimed at Mudski and Clunk for fun
  12. The Following User Says Thank You to peterbr1 For This Useful Post:
    Clunk (6th November 2015)
  13. #99
    Apr 2015
    Sorry bout that Pullsyjr, just hate it when people come and say things like band aid fix's and the like, then start blurting off crap like lathe time etc etc it just sounds like they love the sound of their own voice, I would have been more sensible had he show a little respect and discretion to this issue im only trying to help, I was mostly being sarcastic to the 'ahem...banter' so once again I do apologise.
  14. #100
    Nah, no apologies required. I understand the frustration. I'm also partial to some verbal ("textual" sounds rude) sparring. And that bag of popcorn... Oh lord, I need it now!
  15. The Following User Says Thank You to PullsyJr For This Useful Post:
    peterbr1 (6th November 2015)
