29th March 2011, 05:05 PM
Advanced
UHF Aerial
Hey all!
Just curious, what is a good brand uhf aerial to mount on tx 3600 for a patrol GQ
29th March 2011 05:05 PM
29th March 2011, 05:28 PM
SUCH IS LIFE
There's 100's of brands out there but it depends what application you need it for. Long distance flat ground. Short distance hilly terrain, etc.
Check this thread out as well, might help... http://www.nissanpatrol.com.au/forum...ghlight=aerial
________________________
______ 2017 D-Max _______
29th March 2011, 07:05 PM
Ive got an rfi cd-900 and it works great. not a big fan of those broom handles
30th March 2011, 12:27 AM
I am he, fear me
Scalar is about the best then RFI, GME, Mobile One much of a muchness... DON"T buy any cheap sh1t and Uniden IMHO isn't quite up there with GME etc
Given that all the sets regardless of Brand output the same power the secret to a "good" radio is the Antenna, only the Antenna and nothing but the Antenna. Stick with the best brands, don't bend the co-ax too sharp (no bend radius tighter than about 3 times the thickness) and a good position will see you right.
IMHO the RFI Explorist twin pack is prob the best all round choice. It's an elevated feed ground independant with interchangeable whips depending on what you are doing.
I run 4.5 or 6 dB broom handles on my GME as I want the punch from a good co-linear in the flat WA terrain and change to a Scalar 3 dB rubber whip in the trees. I use a steel 3 dB whip on my Wouxun for short range and convoy comms and Unity steel whip around town
30th March 2011, 12:58 AM
+1 for the RFI CD-900 Under 100 bucks with nice heavy duty spring and nifty little connection thingy so you don't need to bore a big hole in your firewall
GU PATROL TB45 | 3" FLEXY LIFT WITH DROP BOX'S | 7" TOUCH SCREEN RUNNING OZIEXPLORER | 33" MT MTZ ON MT SIDEBITER RIMS | XROX TUBE BAR | TIGERZ11 12000lb WINCH
30th March 2011, 06:59 AM
SUCH IS LIFE
Sorry for the hijack Bigboss. Just off subject a bit..bit still kinda on topic.
I run a GME 4.5db Elevated Feed setup but keep braking the whip every 6months or so. What's everyone else get out of their whips???
30th March 2011, 10:36 AM
I am he, fear me
NissPat
Never broken a UHF whip yet... different story for the AM/FM masts tho... been thru 3 of them
30th March 2011, 04:16 PM
SUCH IS LIFE
the evil twin
Hmmm, don't know what the issue is. I'm thinking going a solid aerial with just the main sprung base
30th March 2011, 06:01 PM
Mines lasting well, taken some abuse from trees also
30th March 2011, 10:33 PM
Whippy fiberglass are known for breaking, but not steel.
