27th May 2015, 07:34 PM
27th May 2015 07:34 PM
27th May 2015, 07:42 PM
A mate of mine had his mounted on his old GQ for year like that will no issues at all.
28th May 2015, 11:32 AM
Patrol Guru
Had mine mounted like that for 7 years, no issues. Only connected and used occasionally to run laptop or charge batteries.
28th May 2015, 12:06 PM
Insulate the way its mounted with rubber matting, also remember it'll get hot so even higher up IMO
or build a small cage to enclose it. other than that all looks good.
Trim the cable tie ends with a stanely knife too,
those ends will cut the heck out of the back of your hand
28th May 2015, 12:46 PM
Cheers guys - it seems pretty solid there and gets good airflow. Also still has a three inch gap to the back end of the fridge. Hopefully it will do the trick.
The Following User Says Thank You to FNQGU For This Useful Post:
threedogs (28th May 2015)
28th May 2015, 12:50 PM
what are you hoping to run from it???
28th May 2015, 01:22 PM
Laptop and then general charging of camera batteries etc. Nothing too heavy duty.
Got a 6800 klm trip planned in July and just getting things sorted.
17th August 2015, 07:58 PM
Advanced
Nothing wrong with having there that's where I had mine mounted in previous vehicles and will be doing same with this one, only difference I have mine on other side of barrier so kids can charge theyre crap. I've had this invertor for around 8 years and normally hard mounted to cargo barriers with no rubber and still works good
Steve
_____________
92 GQ TI
18th August 2015, 09:27 AM
Travelling Podologist
Firstly congratulations on choosing what I consider to be the best value 350 watt inverter you can buy. (The Victron Phoenix inverters are excellent quality pure sine units for those unfamiliar with such things - I’ve had several inverters over the years, with a few failures - the Victron units are heavier & much better built, they can also handle consistent higher output than their rating - I ran my 350w one, same as FNQGU’s, at over 500w for an hour & it didn’t falter).
No problem with mounting to the cargo barrier, but if it were me I would put it up as high as possible to ensure it doesn’t get ‘enclosed’ by stuff behind the barrier & to ensure it has plenty of air flow around it. I might even be tempted to put it on the front side of the barrier for that reason (& ease of access). Although you can install them to be switched remotely, I would choose to always travel with it fully switched off. In an accident scenario it is possible the 240v output could become damaged & shorted out onto the car. Not what you want, & potentially deadly to anyone who attempts to rescue you from the wreck.
A Nomadic Life (Blog)
The Following User Says Thank You to Cuppa For This Useful Post:
FNQGU (19th September 2015)
