4th March 2011, 08:12 PM
My TB45e now has more power.
Good day
My Patrol received a chip and stainless steel freeflow exhaust, the head was gasflowed and they did some modification to the airfilter and the cam timing and then it was dynatuned. The BEFORE run was 82.5kw and 234Nm on the wheels and AFTER was 99.8kw and 261Nm. In November last year I did a dynarun at another company and the results were 92kw and 270Nm. Although the results from the 2 companies differ there is definitely an improvement in power. The acceleration from 0-100km/h is faster. At 120 with the overdrive off I don't have to step so hard on the pedal to maintain the speed on an uphill.
Regards
Johan
4th March 2011 08:12 PM
4th March 2011, 08:18 PM
A 17.5% increase in power is a good result.
There will always be differeces between dynos so it's a good idea to get the before and after readings done on the same dyno (as you appear to have done) and if possible at similar ambient temperatures and humidity to get reliable readings.
Tony
4th March 2011, 08:24 PM
SUCH IS LIFE
Mate, well done on the improvement.
The petrol motors go fairly good but can go hard with a few mods!
________________________
______ 2017 D-Max _______
28th June 2011, 11:49 PM
what brand of chip did you use and what sort of power increases are expected from it?
29th June 2011, 05:45 PM
It is a Dastek chip which is developed in South Africa.
They claim the conversion would do the following :
25% increase in power from std
15-18% increase in torque from std
Fuel consumption should be+- 6km/l on open road travelling 120-130km/h
I get 4.2km/l in town and 5.5 on the open road.
I bought a 2004 4.8 Patrol a few weeks ago and will be selling the 4.5 soon.
9th July 2011, 02:21 PM
Advanced
wow what a difference, i have a tb45 myself but duel fuel gas/petrol, can those same mods be done with running gas to, do u know?
10th July 2011, 05:40 PM
We don't use gas in South Africa, only fuel. I don't know if this will work with gas.
1st October 2013, 01:39 AM
gud fday, this chip we are referring to - where can i buy online? is it something I wilput/ where/ in order to get this results, Thanks
12th October 2013, 08:52 AM
do you know if i can install the chip to my tb48e 4.8 2006
thanks
12th October 2013, 11:29 AM
Legendary
http://www.dastek.co.za/about_the_unichip.htm
This site should answer some of the questions.
1999 GU 4500 dual fuel
Il dado è tratto
