22nd November 2014, 04:20 PM
These are great
http://www.ebay.com.au/itm/141097764...84.m1423.l2649
Hi all,,,, highly recommend these for your tool kit, works heaps better than the non peizio style,
could use it for soldering, I used it for heating and bending steel rod up to 10mm I think
you could make a heap of things for around camp, very handy IMO
The Following User Says Thank You to threedogs For This Useful Post:
Sherro (23rd November 2014)
22nd November 2014 04:20 PM
22nd November 2014, 04:54 PM
Got to be better than the little one I got from super crap, says it can get up to 1300 degrees but wouldn't melt aluminium weld stick that's got a working range between 574-632 deg...
24th November 2014, 10:41 PM
Travelling Podologist
These are great for starting a fire when the wood is a bit damp, but the one I had, after a few uses no longer sealed properly on the canister. I consider myself lucky that I noticed this before igniting it!
A Nomadic Life (Blog)
The Following User Says Thank You to Cuppa For This Useful Post:
Stropp (25th November 2014)
26th November 2014, 09:16 AM
There is a small "O" ring you need to be aware of and all will be good
