11th November 2014, 11:20 AM
Intermittent shudder or vibration at 800 to 950 rpm
Hi. My GU with TB45 automatic puts out a shudder at around 800 to 950 rpm coming from standstill. The whole rig vibrates until I go past 1k rpm. This happens 50% of the time. This just happened last week. I had atf and filter changed two months ago. What are your thoughts guys.
11th November 2014 11:20 AM
11th November 2014, 11:28 AM
Legendary
Does it do it standing still. Put it in park and run through that rev range. Then try with it in drive but brake on so it can't move. Also might be worth driving it and manually changing gears to see if it is rev related or speed related or just before or after gear change.
11th November 2014, 11:29 AM
engine mounts OK check all bushes as well
11th November 2014, 01:09 PM
Patrol Freak
Did you get to see the magnet in the pan when they took it off? That's generally a good indication of expected future trans life..
You can also run a diagnostic through the mode button on the central console. Check the FSM for details.
John
11th November 2014, 06:22 PM
Hi Three Dogs,
The mounts or bushes are okay.
Hi JFF45,
I wasn't around when they serviced my rig. Care to elaborate how to do the diagnostic on my 2001 GU TB45?
Hi 4bye4,
will do what you said and post the resaults.
11th November 2014, 07:54 PM
Patrol Freak
The factory service manual has very clear steps on how to run the diagnostics. It explains how to translate any errors that appear.
John
11th November 2014, 10:17 PM
I don't have the manual yet. Can someone send me a link where to download.
11th November 2014, 10:38 PM
Dribble Master
Zhing1
Think this is what your after in this thread
http://www.nissanpatrol.com.au/forum...ead.php?t=4202
12th November 2014, 10:24 AM
Hi 4bye4. Its a speed problem. It only happens at take off.
12th November 2014, 11:08 AM
Legendary
Hi Zhing, makes me wonder if its the output side then. Maybe tailshaft or universals? Hopefully someone else can add some light.
