2nd March 2011, 09:21 PM
RIP - valued member and true gentleman of this forum that will be missed by many!
Starting axle into carrier
Hi,
Once the axle is inserted into the spline less part of the carrier, or whatever it id that the axle goes into inside the diff, are there any tips for getting the splines to engage and thus allow the axle to slide the rest of the way in?
On the couple of times I have done this I have resorted to ignorance, bad language and frustration - and eventually the axle has slid in.
Would welcome any tips or tricks to reduce frustration
2nd March 2011 09:21 PM
2nd March 2011, 09:39 PM
I've always found just rotating the axle slightly is enough to get the splines to line up and the axle to slide in.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
2nd March 2011, 10:15 PM
If the same as real truck axles, there is a taper just before spline try to lean down on stud end of axle so as to allow spline to rise upto center and feel for the fit.
Tim
The Following User Says Thank You to Finly Owner For This Useful Post:
3rd March 2011, 09:47 PM
thanks!! will try both
We ran into a new problem today on the mate's ute - the replacement CV is too big to fit into the trunnion housing on the end of the diff - even with the flat spots on the CV lined up. Suspicion is that it is a bigger CV to suit a turbo.
3rd March 2011, 10:16 PM
The bigger CV is most likely out of a GU.
Tony
17th March 2011, 01:38 PM
YNOT
Tony
That sounds like the problem as their isn't any differances with turbo vs non turbo CVs
