25th October 2014, 06:24 PM
Legendary
Rear adjustable panhard rod - DIY
Hey guys,
I'm just wondering, isn't it possible to make the existing panhard rod into an adjustable one by cutting it in half and welding a thick enough high tensile bolt & a nut?!!
I'm talking about a GQ Patrol.
25th October 2014 06:24 PM
25th October 2014, 08:46 PM
Legendary
If you want it adjustable on car, without taking if off to adjust, then no, as you will need a coupling with a left and right hand thread on each end of the rod to make it adjustable.
If you want to adjust it off the car then it is possible but I wouldn't want to do it, as what would happen if it snapped and your car became uncontrollable and you killed someone ... I would not take the risk for the $200 - $300 on a fully engineered one from a reputable supplier. Either way, welding a bolt and nut could introduce a weak point that could bend or break under the massive loads when out four-wheeling
Mic
25th October 2014, 10:28 PM
Patrol Guru
Mate don't waste your time. The factory ones are made out of rice paper! Just buy one and save your time and the headaches!!
GQ Snorkle Lockers front n rear
25th October 2014, 10:52 PM
Yes totally agree with both above.
26th October 2014, 12:05 AM
Moderator
Me too Mate. The factory ones are paper thin and not worth the trouble. To answer your question directly though Yes. You can actually buy a weld in collar kit to so that exactly on eBay, I don't rate this as a viable modification though as the factory unit is so weak. Buy a decent adjustable one IMO
http://m.ebay.com.au/itm/131318328526?nav=SEARCH
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
Stropp (26th October 2014)
26th October 2014, 02:15 PM
Legendary
Ok, cool. Thanks guys. Point is taken & I won't waste time on this DIY then. As you explained, the risk is not worth the trouble, and perhaps time & money as well.
I like DIY stuff, but not at the cost of safety.
Cheers.
