Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Uh Oh... The hissin' Nissan...
    Patrol Freak kevin07's Avatar
    georges hall
    when the motor is cold start it up with your hand moving around the egr pipe under turbo and get someone to give it a light rev and see iff you can feel any hot air if so make a plate and block that side as well.
    13 y62 the beast that burbles
  2. #12
    Sep 2014
    No snorkel, no. I have noticed between the two halves of the turbo near the base of the actuator there is a small amount of black soot, from what I can see there's no soot on the engine block behind the turbo. It looks as if it is coming from the 'centre' of the turbo. A seal in the exhaust side of the turbo gone? Maybe the gasket where the dump pipe is bolted to the turbo?
    Grrrr....
  3. #13
    Sep 2014
    Ayr
    Definitely shouldn't be soot around that area. I agree with Kevin, while cold start it up and feel around the turbo for air/exhaust coming out.
  4. #14
    Sep 2014
    Tried your suggestion, couldn't feel any hot air coming from anywhere..... Blahhh totally over it. It's gonna get sold I tell ya. Tired of forking out hundreds of dollars to mechanics to fix $50 gaskets.
    I can't do anything with it, don't have the tools or know how. Much easier to sell it and let someone else have the headache...
    Just had a long weekend here, was intending to go away for the weekend but couldn't risk the car breaking down in the middle of nowhere, so wasted an entire weekend dicking around with it.
  5. #15
    Sep 2014
    Ayr
    Has this happened after you fitted the Dawes valve? If so I would check all your Hose connections
  6. #16
    NT
    Sell it if you want... This is where you either decide to fix, or sell. If you fix, you're either paying someone, or you do it yourself. (sorry to be captain obvious here).
    There is a certain amount of diagnosis you can do, which could reduce the overall amount pages to a mechanic. The other option is you divert money going to the mechanic to tools, and educate yourself. We all had to start somewhere.
  7. #17
    469 Post(s)
    Remove the air filter and take it for a run and see if the noise changes. This might point you at whether its intake or exhaust.
    Also its a long shot and I dont know how you would check, the cat might be blocked... is it lacking power at all from normal?
  8. #18
    Jan 2013
    Adelaide
    Mine does the same and has soot under the heat shield. Cause was the 3" exhaust system that didn't have a support bracket off the dump pipe and was too much weight hanging off the 3 studs on the turbo so the dump pipe was leaking off the turbo. Fixed the bracket issue just need to remove the dreaded heat shield to replace the nuts and re-tighten the dump pipe😄
    2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
