Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Uh Oh... The hissin' Nissan...
    Sep 2014
    Hello all my learned colleagues, I hear the onset of yet another issue with the trusty old ZD30.... When I accelerate lightly I can hear a 'hissing' sound, also when I back off the accelerator the sound is more evident. Doesn't seem to be affecting power (such as it has). I have checked all IC hoses etc etc. Could it be a leaking/failed actuator on the turbo? The dawes valve dumping over boost? Something more sinister in the wind perhaps?
    Any suggestions or ideas would be greatly appreciated.
    Andy
    Perth WA
  2. #2
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Is it an exhaust leak?
    1999 GU 4500 dual fuel
    Il dado è tratto
  3. #3
    Sep 2014
    Ayr
    More information would be helpful, what is the boost pressure against? Did this start happening after anything? It does sound like a possible exhaust leak or intercooler leak. I would go over all hose clamps just to be sure as well
  4. #4
    Patrol Freak kevin07's Avatar
    georges hall
    is your egr blocked it could be a split pipe.
    07 crd,,bridgestone 697lt, 2.75 buedesert ex, SOLD theres a lot of my blood, sweat and money in that troll.
    92 gq ti tb42efi my brothers gq extractors dual batteries brake controller uhf alloy bullbar SOLD with a heavy heart but gone to a nice young fella
    13 y62 the beast that burbles
  5. #5
    Sep 2014
    The EGR is blocked off & the EGR pipe was recently replaced due to being warped. Also replaced the IC with a new one. Hissing sound is coming from the LH (kerb) side of the motor in the region of the turbo. Don't think it's an exhaust leak as there's no 'fluttering' sound.
  6. #6
    Sep 2014
    Recently replaced EGR pipe as it was warped and blocked off the EGR & fitted a Dawes valve while I was at it...
  7. #7
    Sep 2014
    Boost hovers around 12-16psi, Replaced IC the other day, EGR blocked off & EGR pipe replaced also. Hissing is coming from the turbo side of the motor in that vicinity. Rechecked all hose clamps. I'm stumped...
  8. #8
    Patrol Guru
    May 2012
    NT
    Bung missing, eg egt sensor or bung where the sensor would fit?
  9. #9
    If it goes PITOO you may find the exhaust is cracked behind the turbo on the weld.
    It could also be a loose or cracked EGR pipe
    wouldn't read much into it another member was told he needed a new motor cause the EGR pipe was split, go figure
  10. #10
    468 Post(s)
    Do you have a snorkel fitted?
