Results 1 to 10 of 10
Thread: air conditoner
    Oct 2010
    newcastle
    air conditoner
    how can i test the air con in my truck as it wont work at this time
    First thing, check the belt, is it on and is it tight? Next check the fuse. After that you need to find out if there is gas in the system but that requires specialist equipment.
    Tony
    Oct 2010
    newcastle
    thanks tony have a look in the morning
    Advanced BundyDave's Avatar
    Mar 2011
    Bundaberg
    Get someone to look at the front of the compressor whilst you press the a/c switch to see if the clutch pulls in. Should see it pull in.
    Jul 2010
    Waterford West Qld
    Chech the wire on top of compressor is actually connected and if you you have multi meter, check for continuity.
    Tim
    Behind the RH headlight is the aircon dryer mate, bolted to the top of that is the pressure switch. Turn your aircon on with the engine running and then check for a circuit across those 2 pins and if it does not have continuity then you probably have no gas and everything else will be a waist of time. If that does not engage you have NO CHOICE, time to take it to an aircon man.
    Good luck.
    Nov 2010
    Getting a life...
    38 Post(s)
    My aircon in GU shuts down when engine gets over 100c. Is this a safety thing to stop engine cooking?
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    Yes it is, it won't stop the engine over heating but it will take some load off the engine and cooling system to reduce over heating.
    Tony
  10. The Following User Says Thank You to YNOT For This Useful Post:
    katwoman (19th March 2011)
  11. #9
    Advanced Ted's Avatar
    Mar 2011
    NSW
    So its safe to assume that if the engine doesn't make any extra rev's when pushing the A/C button the whole system is bust? (everything is where it should be)
  12. #10
    Quote Originally Posted by Ted View Post
    Not always. Most engines will have an idle up system in place that when adjusted properly will see little to no drop in RPM when the A/C cuts in.
    If the magnetic clutch on the front of the compressor does not click in when you switch the A/C on with the engine running, then there is a good chance the system is low on gas and the low pressure cut out switch has activated.
    If that is the case an A/C specialist will need to inspect the system to find the leak and fix it. Most A/C repairers will want to replace the reciever drier/accumulator when they repair the system (it's good practice to do this). Depending on the age of the system it may also be necessary to retro fit/upgrade the system from R12 refridgerant to the more environmentally friendly R134A.
    Then again it may be something as simple as a blown fuse!
    Tony
