17th January 2014, 07:58 PM
couple of 4inch lift question..
Hey all.
Im looking at purchasing this 4-5 inch kit for my GQ wagon-
4-5" AmadaXtreme lift kit Super flex Radius Arms
Product #7688
from superior engineering i just have a few questions to clear up. 1- after a bit of research iv decided on this kit so any advice or input is great 2 why is it that the kit doesn't require rear lower control arms and also larger or disconnectable sway bars?? 3 do i not need longer bump stops to fit this kit? and lastly im looking at installing the kit my self have done other 2 inch kits but not the full 4 - will i survive haha cheers
17th January 2014 07:58 PM
17th January 2014, 08:14 PM
Moderator
Hi mate,
First off head over to the Introduction Section and start an intro thread, say g'day when you enter the room mate
You should consider adjustable upper rear control arms to adjust the pinion angle once your done and if you have the cash HD standard length lower arms as they can be very exposed once you start using a decent 4" lift.
You will almost certainly need to extend your front and rear bump stops and you should be talking directly with the guys at Superiors about that mate. Thy should be able to guide you but you will still need to take some measurements and make some adjustments to your set up when your fitting it.
Extended sway bar links will be required.
You will almost certainly need adjustable panards front and rear.
I would recommend Drop Boxes for your caster correction.
Head over to the intro section mate and say g'day please.
Cheers MR
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
89gqpatrol4x4 (17th January 2014), growler2058 (17th January 2014)
17th January 2014, 08:18 PM
Moderator
My GQ with 5" superiors setup with Amadas. Drop boxes no super flex there.
Sent from my iPhone using Motorculture mobile app
Rogue Dung Beetle
MEGOMONSTER (17th January 2014)
17th January 2014, 08:22 PM
If you have done a 2 inch lift you can do a 4inch lift. I just did a 3 and never done one before and survived! Just a case of remove and refit. Had a bit of trouble with trying to get the nut on the lower of the front shock if using armadas but apart from that easy.
GQ Snorkle Lockers front n rear
17th January 2014, 08:32 PM
no worries buddy got a bit exited to ask all the questions - but im now introduced
cheers for the replies
so Mr mudrunner ur rig looks sweet by the way!! yeh i tryed to call superior but they are always closed after work hence perth time..
yeah i thought i needed a few more parts than the kit includes? what other parts will i be looking at that the kit doesn't include?
also are u saying i should just go drop boxes instead of flex arms? am i right in saying that the flex arms mean u dnt need drop boxes ? cheers
And 89 gq cheers for the confidence haha so u went with the armandas hey ? pretty sure iv decided i like them better than the tuff dawgs cheers
The Following User Says Thank You to richo_GQ For This Useful Post:
MudRunnerTD (17th January 2014)
17th January 2014, 08:42 PM
Moderator
Have you got a link to the kit your looking at mate? Post it up and I will have a look at it.
I have drop boxes on both cars and rate them highly. Yep drop boxes OR Superflex. The Arms are nice but it coin. If you have the coin go for it mate.
The Tough Dog are notin the same Paddock as the Amadas mate. Different Planet in fact.
Rogue Dung Beetle
17th January 2014, 09:05 PM
17th January 2014, 09:24 PM
I dont have these but id be getting these ones and do away with the mushroom bushes and it has the drop box already
http://www.superiorengineering.com.a...ducts_id=20309
17th January 2014, 09:42 PM
SPAMINATOR
MudRunnerTD
Hi mate,
Cheers MR
X2 With MudRunner mate. Extended arms or drop boxes
17th January 2014, 09:58 PM
yeah cheers bois - so if im getting this right, im buying the super flex arms so i shouldnt need drop boxes?
also iv done a fair bit of research and decided on this kit from superiour but wld like to hear other peoples choices cheers!
