Results 1 to 8 of 8
Thread: fixed v adjustable panhard rods
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    Ok so after the top bush in the front panhard rod totally disintegrated yesterday I can't keep driving around with screwdrivers jammed in there! Now I have a 3 inch lift and was always planning on replacing the panhards, just not so soon. So what are people thoughts on adjustable vs fixed, bare in mind there is a $190 difference between the two from superior. Thanks
    GQ Snorkle Lockers front n rear
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    I have an adjustable superior rod, I guess I chose the adjustable over a fixed because I can get it right to what I have, and if I change set up, I can just make it longer. I think they are good from 2"-6". Kind of a buy it once deal
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  4. The Following User Says Thank You to lhurley For This Useful Post:
    89gqpatrol4x4 (30th December 2013)
  5. #3
    330 Post(s)
    I run a 3" lift on the GUIV and still run the factory panards. The body is centred and I see no need to upgrade. See if you can find a second hand panard or just replace the bush.
  6. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  7. #4
    Brassall
    That was my other thought. Just replace the bushes.
  8. #5
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    Same here, no problems (touch wood) in the 6 years I have run it this way.
  9. The Following User Says Thank You to TimE For This Useful Post:
  10. #6
    Brassall
    Well should have just replaced the panhard rods! Yesterday driving up camp rd lcmp I managed to bend the rear panhard into a boomerang. Pushed the rear diff to the drivers side and when the tyre flexed up before I stopped it bent the SH*T out of my freshly cut and chopped rear guard!!!!! NOT HAPPY JAN
  11. #7
    Patrol God Stropp's Avatar
    31 Post(s)
    I have adjustable a on my 3" lift as the diff was way off centre when I put it on.
  12. The Following User Says Thank You to Stropp For This Useful Post:
    89gqpatrol4x4 (9th February 2014)
  13. #8
    North brissy
    I would always lean towards an adjustable (pardon the pun ) as each individual vehicle has its differences and having the adjustment it will suit most setups.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
    89gqpatrol4x4 (10th February 2014)
