1st July 2013, 09:36 PM
The Following 6 Users Say Thank You to ozzyboy For This Useful Post:
AB (1st July 2013), Jimmyboyjr4 (29th August 2013), my third 256 (24th October 2013), NissanGQ4.2 (1st July 2013), oncedisturbed (20th October 2013), Warwick89 (20th October 2013)
1st July 2013 09:36 PM
1st July 2013, 09:55 PM
Administrator
Neat finish ozzy!!
The Following User Says Thank You to AB For This Useful Post:
1st July 2013, 10:25 PM
Dribble Master
Very nice very well thought out set of drawers you got there mate
The Following User Says Thank You to Clunk For This Useful Post:
22nd September 2013, 05:59 PM
How'd you keep the cost down so low? Left over stuff from other projects?
23rd September 2013, 03:28 AM
They look really good man, makes me want to rebuild mine and do something similar.
Live life, Love life.
Snatch straps on towballs can harm and/or kill!!!!!!
The Following User Says Thank You to krbrooking For This Useful Post:
ozzyboy (23rd September 2013)
23rd September 2013, 02:24 PM
soundfx
2 sheets of ply and a couple off cuts courtesy of work . cost = $0
Carpet was a end of roll at bunnings. ( can't remember exactly, but buggar all )
Screws, glue etc I think 30 bucks tops
I stayed away from runners or bearrings for 2 reasons. The laminate on the marine ply slides easy on the base laminate. Not easy enough that they slide by themselves but easy enough. Other reason was the cost. a good set of runners would have doubled the build cost.
I went the height I did to fit whatever I like in the drawers, fit the 80l waeco on top, fit a duel battery in the rhs compartment, all recovery gear in lhs compartment, and the sub in the face
cheers
ozz
TB42E manual 1996 GQ 30 year anniversary
33" maxxi bighorns, 3" EFS & Accessories
The Following 2 Users Say Thank You to ozzyboy For This Useful Post:
AJTich (20th October 2013), oncedisturbed (20th October 2013)
20th October 2013, 09:22 PM
Man, that is great. I've seen a pic of what I want for mine, and your pics, and setups make me think I could do it too.
Can only hope it looks as good as yours.
A&J
The Following User Says Thank You to AJTich For This Useful Post:
ozzyboy (24th October 2013)
20th October 2013, 11:00 PM
#8
The Mad Ozzy
Good job on the setup and finish
www.swat4x4.com
20th October 2013, 11:29 PM
#9
Nice finish mate, better then a bought one.
The Following User Says Thank You to Warwick89 For This Useful Post:
21st October 2013, 06:42 AM
#10
Enjoying the trips
Great build, If you had to buy the ply would you go with the same? Supporting batteries and serious speakers would be better in a heavier construction.
It looks like 19mm which is fairly heavy, as you say the surface is good for the drawers to slide and that is only on that 19mm form ply.... I think.
A lighter ply if used could be fitted with that "Teflon" strip as Drifta Kitchens use. Corners can be reinforced with 40x40x1.4 mm aluminium angle ($26.00 per 3mtr from Bunning's) I am always looking at keeping the weight down.
Like the design and use of space, a good DIY for a good price.
Macca
The Following User Says Thank You to macca For This Useful Post:
