Page 11 of 11 FirstFirst ... 91011
Results 101 to 107 of 107
Thread: NATS Immobilizer light staying on??
  1. #101
    Advanced mojo53's Avatar
    Sep 2014
    Northampton WA
    I am not bothered by the light as i have a dash mat that covers it,until this drama unfolded i had forgotten it was under there for the past 13 years.
    Thanks for all the help.
    2006 Y61 Nissan Patrol TD42Ti Modified Turbo & 3' Exhaust Compliments of United Fuel Injection Perth WA
    Great White Spotties and Bar Light, Ironman Barwork the rest is standard "What more do you need it's Already a Nissan Patrol"
  2. The Following User Says Thank You to mojo53 For This Useful Post:
    MudRunnerTD (23rd March 2021)
  3. #102
    334 Post(s)
    Quote Originally Posted by mojo53 View Post
    SNIP
    I would still like to know what the adjuster screw is in my previous post as i want to check the solenoid for collateral damage after all the violence that happened around it and that adjuster is blocking access to it.
    Thanks to everyone for the advice and especially the photo's they were a great help.
    I am pretty sure that is the Go Fast screw mate. If you have never had your car on a Dyno i would certainly encourage that. the potential from a stock turbo and pump is a significant improvement over factory settings without any real compromise. I would expect to see 20% power gains from a tune.
  4. #103
    Dec 2023
    Hey Guys awesome info here I have same issue. Q has anyone been able to simulate signal from NATS ECU to CSOLU? Thinking it may save destroying CSOLU or is the CSOLU generally at fault? Cheers in advance JK
  5. #104
    Dec 2024
    Russell Island, Qld.
    Quote Originally Posted by Koonwarra View Post
    Hi all, lots of interesting info to try & sort out the same problem on my 2002 Y61 3.0L TDI. I can barely touch the plug going into the back of the I.P., above the 4 outlet pipes let alone remove it. Just above it there are 2 multi-pin plastic connectors. The right 1 is a black 8 pin plug into the main wiring loom but the left 1 is a grey 6 pin plug with a short cable going down to the inaccessible plug on the back of the I.P. Its wire colors are light blue, pink, green/yellow (visible left to right while still connected), & black, white, blue visible from left to right if you disconnect the plug & twist it 180 degrees.)
    Any ideas if 1 of these wires is the fuel cut-off?
    What do the following abbreviations mean: CSOLU, CRD, Y61(GU?), Y62, etc. I haven't found a glossary here yet.
    Cheers,
    Steve.
  6. #105
    177 Post(s)
    Hey mate.
    In case you didn't notice, this thread and the issue is related to the TD42 engine variants with NATS.
    Now I don't know IF the 3L DI and CRD models have the same sort of system... You have to make sure before and IF you go down the "hacking the system with a chisel" road...
    CSOLU = The solenoid at the back of the bump being discussed here.
    CRD = Common Rail Diesel - Your Patrol isn't one of them. Yours is a DI (Direct Injection). CRD 3L variants kicked in, 2007 ish???
    Y61 = The GU series of Patrols. Y60 was GQ and Y62 is the new V8 petrols.
  7. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    mudnut (30th December 2024), vk4khq@ozemail.com.au (4th January 2025)
  8. #106
    Dec 2024
    Aaaah! So simple if it is explained. I am surprised there is no glossary of abbreviations, acronyms, etc on the forum.
    My 3L D.I I.P. looks like it is a Bosch but is impossible to even get the plug off the back socket without dismantling half the engine. It is nothing like the pix of the 4.2L donk, so nothing to hack or bash.
    Cheers, Steve.
  9. #107
    Jan 2025
    lmfao!! I have no idea how you got purchase with the pliers!! I couldnt even see it!!
    Gday MRTD, Will it still work if i trace the cable back cut it there and then hook the correct wire up to 12v? Or does the whole circuit board need to be removed Cheers
