4th January 2011, 02:10 PM
TB42 All Motor
Hey all been talking to a lad on another forum who may be helping me through an all motor build on my TB42.
If anyone has done this before or can help me out with any niggling issues that I may come across when doing such a thing your help would be much appreciated.
Will basically be doing the following:
TB42 bathed cleaned and checked
Head bathed cleaned and checked
New bearings/seals/gaskets throughout
Shaved block/head compression ratio of around 10:1
Shot peened rods
Upgraded cam/springs/rets
XF throttle body
Port matched to inlet/exhaust
headers and full exhaust, hi flo cat and mufflers
Large injectors/pump (already in car)
Haltech E6K tuned
Hoping for around 150-160rwhp
Thanks.
4th January 2011 02:10 PM
4th January 2011, 02:42 PM
The only thing I can add at the moment is be careful running that much compression with a turbo. You will need to keep inlet air temps as low as possible with a BIG intercooler, and keep boost down to stop it pinging. Not as bad if you're running straight LPG.
Tony
4th January 2011, 02:59 PM
Yeah no turbo, just all motor.
4th January 2011, 03:12 PM
OK, I assumed from your other thread this was the same motor you were turboing. I thought your RWHP estimate was a bit conservative for a turbo!
Tony
5th January 2011, 07:25 AM
Yeah my car atm has a turbo atm but are going back to NA for some unknown reason
Decided to use the engine in my patrol and crack it and refurb.
18th February 2012, 06:05 PM
