12th May 2013, 06:45 PM
Hardcore
Gu dash lights
I changed the dash lights to a blue led set and they won't work except for a few so I put the original ones back and they won't work except for the same few so now I've got no speedo rpm one indicator lights not working any ideas. Do the socket things the globes go in wear out?
IF ITS NOT BROKEN IT MUST BE A PATROL
12th May 2013 06:45 PM
12th May 2013, 06:56 PM
LEDs will only work when installed one way. Did you try puling the LEDs out that didn't work and put them in the opposite way?
Try adjusting your dash light dimmer switch to full brightness (if your vehicle has one).
You may need to adjust the tension on the bulb holders.
Make sure the main connectors on the back of the instrument cluster are fully pushed in.
12th May 2013, 07:01 PM
Beat me to it Yendor X 2 T10 only work one way
12th May 2013, 07:24 PM
Hardcore
