Results 1 to 9 of 9
Thread: lane poole reserve info needed
    Advanced
    Mar 2013
    perth wa
    hi guys thinking of going to lane poole reserve can any one tell me what the 4wd track is like
    Patrol God Stropp's Avatar
    31 Post(s)
    mate last time i was there a lot of the tracks were closed off, you will need to bypass the reserve and keep heading down the road, there are plenty of bush tracks outside.
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    The Captain Fawcett track is a very nice drive, just call into the Information Centre in Dwellingup for a map..............................it is a lot more fun when it is wet but still a nice drive in the dry
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    I have a pdf map somewhere of the Captain Fawcett track somewhere as well as the Lane Pool tracks I will try and find and load up
    www.swat4x4.com
  6. The Following 2 Users Say Thank You to oncedisturbed For This Useful Post:
    GU4PLAY (14th April 2013), Woof (13th April 2013)
  7. #5
    Advanced
    Mar 2013
    perth wa
    thanks look forward to the map also i will be going in about a months time so hopefully a bit wetter
    Quote Originally Posted by oncedisturbed View Post
  8. #6
    W.A. (wandering aust)
    Quote Originally Posted by GU4PLAY View Post
    The Captain Fawcett track is a nice drive (make that a very nice drive) but don't expect to use the stubby lever very much.
    For example, you can do the main track very comfortably towing a camper.
    The main track meanders quite close to the river from time to time.
    When it does I suggest you pop down some of the side tracks as there are a few terrific smoko spots/summer swimming holes.
    Winter time can be 'interesting' if it is just after a storm and trees are down.
    The best play area albeit not very big is down around Tumlo Crossing.
    There is the river crossing to the eastern side if the levels are down but be careful of the closed areas on the other side.
    The Dieback DRA begins up the road a bit and the pine plantation is a no go as well but the fire break around the outside is OK.
    Back towards Dwelly on the western side is a nice hillclimb and a few great spots for pic's.
    If you want some more serious 4WD time then shortly after Tumlo you hit the Harvey Road.
    Turn right towards Harvey (not left to Quindanning) and have a play in the Harvey Dam region.
    The tracks to the North and East of the Dam south of Honeymoon Rd are fun.
    Look for Honeymoon Road on the right shortly after you cross the Harvey River near Stirling Dam
    The MOST fun of all is just having a drive and an explore.
    Just be aware of the DRA boundaries if you cross the River and obey the signage and all will be goodo...
  9. #7
    Advanced Nvd323's Avatar
    Jun 2013
    Perth , WA
    Hit this area a few weeks back is alot of fun in the wet some areas are very easy though
  10. #8
    Advanced
    May 2012
    Perth WA, NOR
    Its a nice drive. Check with the local ranger as sometime it is closed.
    Patrol GU8, Manual, snorkel, steel bull bar, Simpson Ed
  11. #9
    Feb 2012
    30 Post(s)
    Maps of area
    Attached Files Attached Files
    www.swat4x4.com
  12. The Following User Says Thank You to oncedisturbed For This Useful Post:
    Avo (15th July 2013)
