12th March 2013, 09:36 PM
"suspension stuff flexy products"any advice or reviews, pictures
I have seen a few posts about ss products but mainly only 2" flexy coils . is there any advice or information reviews on the bigger lifts like 4" and what shocks would you run with them as they have an extra 2-3" inches of flex . pictures and reveiws would be awesome.
12th March 2013 09:36 PM
13th March 2013, 09:30 AM
I have only recently fitted 4" flexy coils to the rear of my GQ, I didn't get a good chance to test them due to a back injury soon after fitting them. I did flex them up once and was really happy, I have got 6" rear shocks and the springs were no where near to coming out. I will give a better review in a few weeks once I am out of hospital and get a chance to drive the patrol a bit more.
13th March 2013, 11:37 AM
cheers for that so would you say go bigger than 6" shocks ? lookin forward to gearing more about the ss stock
13th March 2013, 07:50 PM
Smart like tractor
Gu with stacks
you wont really need bigger in the front unless you are running superflex arms.
I have a 4inch lift with superflex arms and started out with 12in, then dropped to 11in and my latest set (when they finally arrive grrrr) is down again to 10in basically I still didnt use the full shock and the longer shock affected my up travel that why I down graded.
The rear is a different story I you want to modify your bump stops and use coil retainers and drop out cones you can fit a shock with a decent amount of travel. I have managed to fit a 14in travel shock in the rear without too much drama.
96 GQ coil/Cab
08 G6eT
13th March 2013, 08:41 PM
thanks for the input , what kind of shocks are you using ? how expensive ?
how much was ur set up if you dont mind me asking
13th March 2013, 09:17 PM
Smart like tractor
the shocks are King racing shocks, remote resovior smoothies. They arnt cheap thats for sure but I have gone through a few sets of cheap shocks way too quickly whixh gave me the sh1ts so I didnt skimp this time around
96 GQ coil/Cab
08 G6eT
13th March 2013, 10:27 PM
Moderator
Ben-e-boy
Mmmmmmmm Kings!!! Mmmmmmmmm.
^^^^^^^^ really nice set up ^^^^^^^^
Check out my Toy -->
Rogue Dung Beetle
10th December 2013, 08:32 AM
Had a search and couldn't find an answer. Has anyone installed a flexi kit themselves? I have access to a forklift but my question is with getting the new front coils in. Do I need to compress them or once I disconnect the brake line and breather will I be able to simply lift the front of the truck high enough to slip the coils in? Thought Id ask before I damage something.
Thanks in advance.
10th December 2013, 09:34 AM
Moderator
kyle300exc
Thanks in advance.
take the wheels off and your diff will drop down a heap more.
Rogue Dung Beetle
