10th December 2012, 02:51 AM
5th gear missing/not there
Hey Guys,
So here is the drama, I have a 92 TB42e GQ LWB and after some rather tame 4wding in some sand today, I mean really quite tame, I was on the way home and jumped on the hwy and went to change from 4th to 5th and nothing, let the clutch out and it was as if it was in neutral. You can freely move it into the spot where 5th should be with the clutch out as if that spot is part of neutral.
Any ideas? I've not long ago had this box out to change the clutch and I'd rather not have to pull it out again, but I think that's what needs to happen.
There was no noise or anything or any warning I didn't even know until I went to put it in 5th.
Thanks in advance
Jamo
10th December 2012 02:51 AM
10th December 2012, 02:52 AM
Your box is coming out. Sounds like the gear has moved...
Owner of
Westy's Accessories
10th December 2012, 03:19 AM
10th December 2012, 06:04 AM
PatrolinAlong
How does it move? Odd
Broken retainer clip or guide allowing it to float on the shaft.
If I had the manual on this phone I could screen shoot the exploded view for you
Owner of
Westy's Accessories
10th December 2012, 10:18 AM
21st December 2012, 02:29 PM
So how did you go with this?
Here is a pic of the gears from the manual.
Owner of
Westy's Accessories
The Following User Says Thank You to BigRAWesty For This Useful Post:
MudRunnerTD (31st January 2013)
31st January 2013, 03:30 AM
Hey mate!
I've had a few health hiccups box only just came out tonight, yeah looks like what you said was spot on, what other damage am I likely to have done?
I'll be pulling the 5th gear off tmrw to have a look. Looks like the spring, the three locking pins, the washer n retaining clip pushed off
Jamin
31st January 2013, 10:17 AM
Re: 5th gear missing/not there
Given the clips and crap sunk straight to the bottom, without going threw gears, then damage is probably nil.
Owner of
Westy's Accessories
31st January 2013, 10:21 AM
Moderator
Hey Kallen, have you got the manual on your phone yet? I have it on my iphone in full pdf on my bookshelf.. Whether Android or iphone i think you should be able to do that mate?
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
BigRAWesty (31st January 2013)
31st January 2013, 11:36 AM
Yea mate. Both manuals
Owner of
Westy's Accessories
