30th November 2012, 08:33 PM
Turbo Timer!
hey guys i own a 2003 gu patrol and i am currently putting a turbo timer in but i am a bit confused.
i know the red goes to the battery and black goes to negative but the blue is acc and the yellow is for ignition but i dont know which wires they are in my car going into my ignition switch?
30th November 2012 08:33 PM
30th November 2012, 09:18 PM
Have you got a multimeter mate, just back probe ur ignition barrel and u should b able to find it pretty easy if not just pick up ur 12v from sumwhere else
30th November 2012, 09:28 PM
yeah i do mate, i tried using that but i couldnt work out which one was the ignition cable and which one was the acc. is there a easier place to pick these 2 wires up from?
30th November 2012, 09:34 PM
Possibly behind the stereo or fuse box.
Owner of
Westy's Accessories
30th November 2012, 09:43 PM
The wiring at the ignition switch, the acc should be the Black with the White trace wire and the ignition should be the Blue wire
The Following User Says Thank You to Yendor For This Useful Post:
MudRunnerTD (30th November 2012)
30th November 2012, 10:02 PM
trolling
When u turn the key 2 acc ull only b puting 12v out one side so once uve found that ur set, same as ignition just follow the voltage when u turn the key
30th November 2012, 11:52 PM
ohhk cheers for the help guys. Got it working
