25th November 2012, 02:05 AM
tyre size options
In regards to the tyre size laws, does anyone know what the largest standard or optioned tyre was for 99 gu wgn,,
When I bought mine it was fitted with 265/75/16's I use them on the street but when heading for the tracks I put on 315/75/16 mtz's, I am hopeing somewhere it can be proven that a 285/75/16 was optioned allowing a 315 to stay within the legal guidlines,,,,,,,,
25th November 2012 02:05 AM
25th November 2012, 07:23 AM
Hardcore
I think 286/75/16 or 305/70/16 is as big as you can go legally
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
The Following User Says Thank You to macca86 For This Useful Post:
25th November 2012, 07:36 AM
Not 100% if its 2" bigger rims or 1" bigger rims to whats stated on the tyre placard on inside of front door. I run 305s and they are legal but I wanted to run 315
but had just fitted suspenion lift on, still think 315 are legal its the rim size that they frown upon like 16" x 10". As long as you're inside the guard what can they say. look at the Icelander Ziggybuilt 4x4 that are driven ove here on 44"s.
This would mean a DX can legally only run a 7" rim anything over is illegal up from 6" std rims
The Following User Says Thank You to threedogs For This Useful Post:
16th December 2012, 01:30 AM
Patrol Guru
G&D, 285/75/16 was never optioned on any GU, this is a 33" tyre, standard is a 32" tyre, you can go up to a 33" tyre legally on a 16" rim, further to that you can also go to a 16" -13mm (negative 13mm) rim which will give you a wider track, actual allowance is 25mm in total, -13mm will give you a total of 26mm wider track. Anything bigger or wider is technically illegal, this is really only an issue with insurance as they can become technical on this stuff sometimes, at this stage you can lift your vehicle 50mm or 2" in suspension & appx 25mm or 1" in tyre height, after that technically you are suppose to engineer changes
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
16th December 2012, 01:37 AM
Patrol Guru
Threedogs, a DX can run 16 x 8 rims as it was fitted to a GU, you only have to fit flares from a ST or Ti, all part of the range for that vehicle so acceptable for any GU regardless of it being a DX, ST or Ti
