Any suggestion on how to reconstruct or replace the worn-out rubber/plastic coatings or covers of strikers? Doors seldom opened have still the tendency of wearing the striker's cover. Doors squeaks soon if these are not fixed. Buying a new Striker is not the only remedy, right?
They wear out with a bit of vibration with the door closed too damn it. Probably only buying a new one would fix it although none of mine still have a cover on them in the GQ and that is OK. Not sure about my GUIV? Never checked.
Sorry No Help there ^^^^^
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
I've used shrinkable tubes by cutting longitudinally, paste the ends using smart glue then apply heat so so that it would fit. Made two layers but still wont last a bit. 6 months its gone again. I haven't tried the nitto tape (an electrical tape that hardens in low heat). Maybe good in the side doors but i doubt if used at the rear ones, the rear door is too heavy. I shall try anyway. Thank you for the responses.
Nylon air tubing. Can't remember what size but it works. this tubing can be bought from truck spare parts or hose places. Either that or go to the wreckers. I got some good second handy's for stuff all. You can also adjust them in a little to pull on the door tighter when closed...
You can remove two large screws that hold the striker to the car, and then just refit the striker upside ,so now the lock rubs on a brand new bit of plastic, then use electrical tape to tape up the split side (that now wont get disturbed by the catch)
