Results 11 to 20 of 25
Thread: TB42s loss of power
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Sweet, I'll just crank it till it roars into life:-)
    Tap, crackle, pop
    Hello from Under Down Under!
  2. #12
    Did the new filter fix the problem?? not sure on your carby but you may have a small inline one on the carby as well
  3. #13
    Aug 2011
    North West Tas
    56 Post(s)
    Haven't fired it up yet, having a BBQ lunch and the obligatory fresh Tassie beers:-).
    I've read that the earlier MQ and MKs with the P40 petrol engine have an inline filter in the carby but I don't think the TB42 does....
    Tap, crackle, pop
  4. #14
    Banned
    That looks alot like rust from the pics Lucas & if its come from your tank I'd say your copped some fuel with water in it. Petrol will float on water which leaves the water sitting in the bottom of the fuel tank to rust.
    If you disconnect your supply line from your filter & using a rag wrapped around an air gun put around 2 to 3psi pressure in through the filler (fuel cap) you will be able to blow through all the cruddy fuel & once its empty you can splash some fresh fuel in & do the same to flush the tank & clear the lines.
    Obviously this would need to be done with the fuel tank close to empty.
    Also keep a fuel filter handy to do a swap in a week or two as it will probably suck a little crud through over the next few drives.
    One more thing.... Check to see if you have a filter at the tank end of your fuel line?... Sometimes they get fitted there as well.
  5. The Following 2 Users Say Thank You to patch697 For This Useful Post:
    taslucas (13th October 2012), Yendor (13th October 2012)
  6. #15
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by patch697 View Post
    If that doesn't work you may need to remove the fuel tank and give it a clean out.
    Paul what are your thoughts on adding a little 2 stroke oil?
    At least it might help add a protective layer to the fuel tank???
  7. The Following User Says Thank You to Yendor For This Useful Post:
    patch697 (13th October 2012)
  8. #16
    Can't see how adding 2 stroke would coat tank, thinking that would just wash off.
    If your plans are to keep Patrol for a while, do as suggested remove and clean inside properly.
    You'll only get the same issues later and maybe more remote?
  9. #17
    Banned
    I don't know Rod, I've not ever tried it. I'd think it would wash away pretty quick but it's worth a look all the same.
    Given how clean the inside of a fuel tank is generally kept by the fuel unless it's been sitting for a while with water in it & the rust has a chance to bite right in, any rust that develops from cruddy fuel is generally only a slight surface rust. In some cases its enough to become a problem when mixed with the crap thet coursed it in the first place but once cleaned out generally doesn't cause any problems, I am talking in general terms here though.
    I don't go right for removing the tank rather clean it first (re my last post) & if that doesn't fix it then I'll pull the tank out to flush out any shale & crap that might be sitting in the bottom.
    Given the fact in Lucas's case his problems only occurred after he's last refill is why I suggested what I did as I recon he's picked it up quite early & there is a better than good chance no real harms been done.
  10. #18
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I was thinking it would need to be added every 2nd or 3rd tank.
    Once the rust starts inside the tank it normally hard to stop it, maybe.....just maybe the 2 stroke oil might help with this?????.
    I have been reading up a lot lately about adding 2T oil to diesel fuel and how some people have found when adding it to their tank for the first time it seems to clean out their fuel tank.
    I thought your post was brilliant, I like the simple things..lol
    Do the carby models run the sock on the end of the pick up in the tank?
  11. The Following User Says Thank You to Yendor For This Useful Post:
  12. #19
    Aug 2011
    North West Tas
    56 Post(s)
    Cheers for the replies guys. I dont think it was just my last tank of fuel. Ive run it very close to empty 4 or 5 times in the last two months or so, so the crud has probably been there all along, i just havent sucked it up before.
    I just fitted a cheap fuel filter and its the clear type. Im going to drive into town about 25ks then have a look to see what its like. If it looks good ill fill the tank up and change to the big filter at a mates place and hopefully not have to worry about it for a while. Ill check the filter again in a month or so to see how it looks.
    Ive heard that its good to wash out a fuel tank with metho because metho is water soluble but will also evaporate. So it grabs the water and then evaporates away with it.
  13. #20
    Banned
    Yeah mate they do but it still lets a certain amount through as you'd know & yeah I've heard the same about the 2T, I'd never had thought of using it as a cleaner in a petrol tank though.... Im keeping that one for future experimentation....lol
    Lucas, Metho is a good way to disperse water in early non fuel injected models but its not safe to use in anything with a plastic fuel sell as it reacts with the material for some reason, just a bit of trivia for you.... all the best with getting your Delmer sorted, I thought I'd give you some food for thought but you seem to have it all well under control so I'll stop semi hijacking your thread.
    Paul
  14. The Following User Says Thank You to patch697 For This Useful Post:
