this weekend we went away, towing the camper & the first hill she heats up off the dial, second decent hill & same again, switched the camper over to a mate GU & the next 3 hours are uneventfull, when for a scenic run Sunday morning & driving up dirt hills in 2nd or 3rd & overheats again twice more, Sunday arvo actually get into 4wd no issues for an hour r so, back on the dirt rd in 2wd & first hill she is hot again, when this was happening I hit a small pot hole & the gauge dropped from red to 3/4, stayed for 15 seconds then went down to below half in less than 30 seconds, each time it comes down to normal in a minute or so,
Thermostat? sensor? collapsed hose (is it the bottom one normally)? it was very frustating but no warning lights on
X 2 with above you really need to know whats going on with these motors.
possibly just a bad earth on the gauge, check and re do all earths if possible.
Sent from the secret chambers of our secret society, on a secret iPhone, with a secret pin code and eye retina scanning from a secret peep hole, just don't tell anyone OK, cos it's secret........
When was your last coolant flush also your thermostat might be broke as its not hot all the time or you have air in the system
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
