5th September 2012, 10:48 PM
Advanced
Rust
I has anyone had rust issue with their patrol. I have a little bit of rust under the roof gutter
5th September 2012 10:48 PM
5th September 2012, 10:55 PM
Hardcore
Yes, I have a bit of rust where the spotwelds are, but it's a 98GU.
Seeing as yours has been bogged in very salty mud, I would be having a good look under, maybe that's ya gearbox problem, better get that chassis hosed out asap
Cheers, the ferret.
6th September 2012, 10:37 AM
Administrator
Yep found some 5 cent piece size spots in my gutters. Very good spot for it.
Check the rear slide side windows on the bottom as well.
6th September 2012, 11:04 AM
Get some rust converter on it quick smart and coat it with " LANOTEC" get product.
Hope all your looms are ok if the 4x4 came from a salty enviroment?
GQ were famous for rusty rear window surrounds , sliding mainly I think
AB did yours used to have a pack rack on top???
6th September 2012, 12:49 PM
Administrator
threedogs
No nothing on top. The water just sits in the gutter and the previous owner didnt use it much so stagnant car with water in gutters are asking for rust.
6th September 2012, 12:50 PM
The 747
Mine has no rust in the gutters luckily. Also very minimal rust in the rear windows too but I want to replace those with solid units anyway, so would get rid of that rust at that stage.
6th September 2012, 02:16 PM
Open the barn doors and gently pull off the rubber seal sitting against the body (at roof height)
Rust?
Tipsy-tap
