5th September 2012, 07:38 PM
the grey ghost is sick!
need some help guys,
went to drive the ghost (1981 mq 2.4 ltr petrol) to work this morning and she drove like a dog! is backfiring badly and running like its missing. its all of a sudden so we are thinking coil or distributor......thoughts?
5th September 2012 07:38 PM
5th September 2012, 07:42 PM
If running on gas and doing this I'd
be checking the leads. whilst its dark ,lift the bonnet and start it up
Thinking there will be sparks everywhere
5th September 2012, 07:51 PM
Hardcore
Points mate, check the points and the dizzy cap.
Cheers, the ferret.
5th September 2012, 07:54 PM
new points and dizzy cap Ferret.
5th September 2012, 07:59 PM
Hardcore
Ok, water in the fuel, ballast resistor, cracked plug, bad earth to engine block, coil or condesor??points bottoming out??
Cheers, the ferret
5th September 2012, 09:34 PM
Is the alt charging - if you have low volts will casue this as well
1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
And its Toooooooo High for the Ball & chain
The Following User Says Thank You to GQ TANK For This Useful Post:
threedogs (5th September 2012)
6th September 2012, 06:45 AM
thanks Ferret thats a great list to check . Shes got new plugs and a new alt Tank . we where thinking points bottoming out or coil to Ferret. ill start with the cheapest first and replace the coil today.
7th September 2012, 09:09 AM
L28s absolutely hate batteries not fully charged
Check the battery
7th September 2012, 04:33 PM
have replaced coil , check points , spark , fuel, (no batt but brought one 6 months ago). the only thing we can think of is there is play in the dizzy to the cam putting the firing up the shit(have recently done new cap and points). so im on the hunt for a second hand dizzy "sigh".......and she was running so well!
8th September 2012, 10:43 AM
So you bought a new battery 6 months ago ???
If it was a newie still could be an issue
if it was a replacement , ala 2nd handie,it could be a dud
I had an L28 here run that ruff it struggled to rev or idle well
Threw a big battery from a diesel in it ,(cant remember why we done it) and it was like a new engine
Ran like a tropper and screamed like a pig at a slaughter house
Not saying thats the issue,but just double check it with a volt meter
The other issue with the L28s is the fine filter just inside the carb,when these block , no battery,coil,leads,plugs will make it run better
Check that filter wont take long
If you need a dizzy, shoot me a PM ill checkout if theres a spare here
