16th August 2012, 03:02 PM
Just blocked EGR now engine waring light on.
I'm new to the forum so hi to everyone!
I have just finnished blocking ERG and now the engine warning light is on. the patrol is running fine but a bit worried about the warning light being on. if this is normal i'm wondering if the is a way to turn it off?
16th August 2012 03:02 PM
16th August 2012, 03:27 PM
Good question, I'm about to do this to my car but have pink slip inspection coming up so I'm a bit apprehensive, how'd did you get on with it?
Hardcore
Hi mate what model year and motor do you have as they react differently then someone with more knowledge can help you out
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
16th August 2012, 03:53 PM
Its a 2000 3ltr zd30 DI. just had another look over it and all looks fine everything back where it should be.
16th August 2012, 04:15 PM
The install was fairly easy it's just a bit hard loosen bottom bolt on the flange below, you just have to keep at it and it comes loose. I had a pre made plate from ferret tools so it just slipped in. I don't think they would even notice when inspecting. Cause looks like normal gasket. Unless they do emission testing they would know.
16th August 2012, 05:29 PM
Just tried bridging the 1 and 8 terminal to read codes and reset but didn't work. Just worried it might go into limp mode. Any ideas woul be great.
16th August 2012, 08:01 PM
Rotaredom
Hi mate, an intro in the introduction section ( found in my signature ) would be nice, so members knew who they are talking 2
Todd
