23rd July 2012, 11:44 AM
Daily Lurker
33" Tyres on 2inch lift
Hi Guys,
just curious to know if 33 inch tyres with a 12.5 offset will fit on a patrol with a 2inch lift? any input much appreciated.
cheers
nic
edit: they would be fitted to size 7 offset 15s
23rd July 2012 11:44 AM
23rd July 2012, 06:35 PM
Patrol Guru
Sorry mate, your question does not make sense. The offset refers to the distance the mounting plate of the rim is away from the centre of the rim, IE a -6mm offset will be 6mm closer to the the car from the centre of the rim. On a GQ you will need some negative offset rims to fit a 12.5 inch wide tyre so that it misses the guard and inside of the wheel arch on up travel.
If that helps awesome, if not let me know and I can answer some questions.
Adam
They've done studies, you know. 60% of the time, it works every time.
23rd July 2012, 06:43 PM
Dribble Master
Think they're on about width........ To fit 12.5" tyres you'll need at least 8" rims, some say 8.5".
23rd July 2012, 08:42 PM
Hardcore
15x8 with -22 offset is what he will want
24th July 2012, 08:36 AM
Patrol Guru
Thats right healy, the 12.5 fit quite well on an 8 inch rim I reckon.
