6th July 2012, 04:37 AM
3inch suspension lift swb GQ still got the shakes
ok ive looked up what needs to be done to eliminate driveshaft vibration, its a swb with 3inch susp lift n 33s, so far its got 10mm gearbox spacer, 3deg castor correction for radius arms and f n r driveshafts have been flipped.
its still got bad vibration, just so i dont over spend, what should i try next or in what order, should i drop the gear box another 5mm, ext control arms (upper or lower?), panhard rod, drive shaft spacers???
6th July 2012 04:37 AM
6th July 2012, 04:41 AM
if i drop the gearbox more can i just add another spacer to the 10mm one thats there or do i have to replace itwith a new one at 15mm thick
6th July 2012, 04:42 AM
im just guessing at 15mm itll prob need more
6th July 2012, 07:27 AM
Ring Micheal at Superior Engineering.
