30th June 2012, 09:30 PM
5 pin relay socket
hi guys i have a gu and was in the midst of fitting/making a headlight relay harness low beam high beam relays etc.
in the engine bay next to the battery is a fuse box and a relay box. The relay box is where nissan have mounted the 5 and 4 pin relays etc.
what im after is the female socket (naked not the pre-wired type) that fits in to this relay box that you would normally plug the relay in to.
main reason is to try and keep it looking all tidy as there is a few spare spaces and not having any joiners thru the harness etc...
any ideas where or who might sell these plugs????
30th June 2012 09:30 PM
1st July 2012, 02:53 AM
if they are a special fit best bet is a wreckers or if the pre wired ones fit you can pull out the connectors inside useing a small screwdriver and get some new ones that slide in and have a prong on the side that lock them in place.
5th July 2012, 09:09 AM
yup ill have to try a wreckers cause they are a special fit thanks...
