Yep, that section will come straight off mate. take out the screw in the Grab slot that you use to close the door then it needs to slot back. it will unhook and come right off.
Not sure if you will fix it when it is off as it looks like it might be stuffed but worth a shot. Otherwise grab one from a wrecker.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Take one off first mate, if they are just cracked from the underside you might be able to stick them back together with RapidFix glue and remould them. Not out of the question. Have a look before you spend the cash. the Wrecker will probably smash you for them.
