26th May 2012, 11:13 AM
Sandpaper choice for rubbing back paint.
I took the snorkel of my troll as there was a little rust. I have sanded back the rust and undercoated it. I have applied a fine first coat of spray paint but what sort of sandpaper should I use in between coats?
I have with me some of the black Bunnings waterproof paper in different grades. Could I use that?
where I have painted it can't really be seen, only a small section just under the snorkel will be...
Thanks.
26th May 2012 11:13 AM
26th May 2012, 11:18 AM
800 grit wet usually on undercoat then when it comes to blending in i would use 1200 and sand the lot on to the already painted area around the job and blend it in.
26th May 2012, 02:54 PM
So use the paper I have. But wet it yeah?
26th May 2012, 04:07 PM
Yeah just run the hose slowly over it as your sanding.
Or use a bucket and sponge
I find the trigger nozzle on the hose on fine spray works better just wash it down every minute or so
The Following User Says Thank You to 97_gq_lwb For This Useful Post:
26th May 2012, 05:04 PM
Thanks. You've been a great help.
12th June 2012, 06:29 PM
I always find it better to soak the paper for an hour or so in cold water, then use a sponge and bucket. you dont want it to clog.
20th June 2012, 11:51 PM
Use a spray bottle to wet the panel.
