6th May 2012, 12:23 PM
GPS reverse Camera
Hi there, i have recently had a dual battery system installed and the dealer fit (VDO Dayton) GPS reverse camera no longer works, was wondering if anyone new where the reverse camera wires from GPS terminate (in cabin, engine bay?)
6th May 2012 12:23 PM
6th May 2012, 12:32 PM
Rotaredom
Post up an intro about yourself and your rig when you get the chance, might find more members are willing to reply 2 a question after an intro has been posted
Todd
8th May 2012, 05:50 PM
Check under the bonnet for any wires around the battery that are not connected as this may have been overlooked when they reconnected the batteries, also if they mounted a switch to override the dual battery solenoid they may have droped a wire off under the dash or connected the override switch to camera feed rather than running a new wire.
If this still doesn't work maybe check your inline fuses.. all else fails take it back to the dual battery installer & make them fix it free of charge.
Cheers Tony
Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
