30th September 2010, 01:29 PM
Replacing Temp Gauge
Hey All,
Just wondering if anyone has pulled out their dash (GU) and if so, did you happen to notice if it was at all possible to replace the temp gauge with an accurate aftermarket one?
Has anyone done this?
TC
30th September 2010 01:29 PM
12th October 2010, 05:44 PM
Doesn't look like it, sounds like a major job.
1984 MK Anniversary Model, LWB,SD33,Air-Con,P/S,Straight Body,Minimal Rust.........Not Bad For Free
12th October 2010, 07:11 PM
Hi Toecutter,
I use software on my car pc that gives me very accurate engine temps through the diagnostic port. I run NISTune, ECUTalk and Scantech for engine and transmission data. Another option is the ECUTalk LCD display, which will give you very accurate engine temp readings along with heaps of other information and the ability to read and clear error codes.
Depending what engine you have, you should be able to find a readout module to give you all the information. Checkout ECUTalk.
The Following User Says Thank You to Chaz For This Useful Post:
NissanGQ4.2 (12th October 2010)
12th October 2010, 08:03 PM
Rotaredom
Chaz
Hi Toecutter,
ECUTalk.
Thanx Chaz for the post, I am currently looking at buying the cable from ECUTalk, not looking at getting the readout module. can you tell me what software on your pc you are using????
Cheers Todd
12th October 2010, 08:05 PM
Rotaredom
Just read your post properly ignore previous post except the thanks part
12th October 2010, 09:20 PM
Haha! No problems Todd, thanks.
If your GQ is a petrol model, you should have a good choice of software available. If it’s Consult1 and injected, you may even be able to fit a daughter board or emulator to the ECU and have control over some engine tuning parameters.
Plenty of software is available.
Scantech Nissan (free) for engine and auto transmission
ECUTalk (free)
NISTune
Nissan Datascan
Conzult etc
12th October 2010, 09:41 PM
Rotaredom
Chaz
ECUTalk (free)
NISTune
Nissan Datascan
Conzult etc
yep petrol guzzler and injected......thanks for the info will look into it some more
