5th May 2012, 01:30 PM
GU patrol factory winch bar bash plate
Hey guys I have installed a tigerz11 winch to my GU patrol with factory winch bar. Im just wondering if anyone has managed to reinstall the factory bash plate after installing a winch. I cant seem to get my hands in there to put the 3 bolts in the back with the winch in the way.
5th May 2012 01:30 PM
7th May 2012, 12:25 PM
Mine has nuts welded on, so you just put the bolts back in from below.
7th May 2012, 12:55 PM
Where did you mount the solenoid?
Any pics?
7th May 2012, 05:11 PM
I used to pieces of strip steal and made up some L shape brackets that bolt to where the number plate bracket used to bolt. My bash plate has 3 bolts that go in from the top and two from underneath at the front
7th May 2012, 09:00 PM
Advanced
Hi,
I just got a finger on it to get the nut started and then put a spanner on it and put a finger on the spanner to hold it down.
Or you could try finding a kid with small hands to help you out.
John
2011 ST Patrol, ARB bull bar with Tigerz11 winch and IPF spotlights. Snorkel, UHF Radio. ARB air compressor and a front locker. Dual battery, Diff Breathers and 2" OME lift and 16" Black Dynamic Steel rims with muddies
8th May 2012, 06:59 AM
Yeah that was my next option, no way my hand will fit behind the winch. damn these bear claws haha
8th May 2012, 10:04 AM
Had the same issue with mine. Only just remembered after seeing this post - haha!! Never did get around to putting the 3 bolts on, just bolted it up with the two front ones, hasn't fallen off yet. May take another look this weekend.
13th May 2012, 08:06 AM
G'Day just wondering what tigerz11 winch did you install and did you have to modify anything at all, i have the same bar and thinking of buying a tigerz11 winch , also can you access the gear lever on the winch ok.
Regards Tonks
13th May 2012, 10:56 AM
I just got the 12,000lbs hercules. I just had to buy slightly longer bolts and I rotated the gearbox so I can access the lever. Otherwise everything bolts up nicely and was very easy with the bullbar removed
15th May 2012, 06:54 PM
Thanks for that,
Cheers, Tonks
