TB 42 mechanical dizzy
a pure gas GQ requies a mechanical dizzy for regular sparks
or once upon a time my GQ had an EFIectomy and was given a gas mask
but her wicked stepmotherinlaw owner never gave her the right to vacum advancement
or even an air/fuel ratio screw
A fairygodmother presented her with a new hi compression head that has all the cool exhaust valves
then sold her to us! as a Work horse float truck
she coughed and farted ,blew the airs filter to bits several times till i figured how to richen the mix
that I'll tell you is a bit of a trick!
now her little ECU is feeling quite lonley down by the passangers feet
the throttle positioner is mute, the vacum sensor is sensless the injectors wont listen , no petrol to be hot ,cold ,pressuried or what!
only the the cranky angle sender is going round and round making her dizzy and forgetfull,
not remembering to msg da coil to shoot the sparks out
right when the timing is dead at the center of the top
a modern motoring fairy tail just for u
based on a true story of ER da GQ
if any one knows where i can get
a real set of points
to put under her bonnet and can get to tune the donk properly
pls let me know
