Hi All,
New to this so bear with me.
I have a 2003 GU zd30 Patrol and the alternator stopped charging the other day so purchased a replacement from Repco down the road. The replacement is a OEX HAX070 which is labled as being the correct replacement.
Why do Nissan make it so hard to replace something as simple as an alternator????
Anyway I got the job done after stripping off everything around it to allow access and took it for a drive. It is charging like it never has.
The problem I now have is that after just under 100k's the belt started squealing so put a little lube spray on it and it stopped. Next morning squealing again.
I have checked all pulleys and the bearings are tight and noise free, I replaced the belt tensioner and belt 10'000k's ago and all seems ok there.
I bought a stick of Dri Lube and put that on and the noise is worse. Once the engine has been running and everything has heated up the noise disappears and then comes back once cooled.
Has anyone used this alternator on a ZD30 before and had any problems as this was the only change made to the engine before the squealing appeared. I have checked the pulley against the old one as best I could and all seems to be the same.
My next step is to buy a new belt for Mr Nissan but don't want to spend $110 if the same thing is going to happen. Going genuine as last time I replaced the belt with an aftermarket one which was 2mm longer and had noise issues which the genuine one fixed.
Any help or advice would be much appreciated as I am going nuts trying to locate the problem.
BEP120
