Coolant leak from the timing cover
I own a 2008 GU ST (CRD) Wagon, I have come across a problem with my Patrol which has been diagnosed with a coolant leak from the timing cover.
The vehicle is 6 months out of warranty ($2500 to fix) and has only travelled 67 000 km, has anyone else come across this problem before with such low km's ?
This has just happened to my 08 Patrol
Hi guys,
took my Patrol to the mechanic today for my 80 thou service. Found a the same leak as you guys have had. This guy had done one before and he reckons after removing the engine, all new fluids, gasket kit (around $1300) plus labour of 15 odd hours I'll be up for $4000.
The car is 60 days and 5,000 k's out of warranty and my extended warranty clearly states that it doesn't cover gaskets. Won't be buying another one of those.
Is the silicone still working for you guys?
I intend to call Nissan Australia on Monday and ask them to warrant it. I'll let you know how I go
Mike.
Patrol is going intothe local Nissan Dealership in the morning.
Quote:
cuzzo
Yeah mate all fixed under warranty. Before I let Nissan work on the vehicle I asked for a diagram of the timing case assembly to see for myself what was required. The dealer I used for the repairs knew of the issue & had repaired other CRD's prior to mine so it must be a common fault. As someone else stated there is no gasket, it is sealed by silicon so the issue is from factory. When booking in the vehicle I actually asked for the clutch to be replaced. Thinking the engine needed to come out, but I assure you it doesn't. Where are you located ?? Ferntree Gully Nissan carried out the works on my vehicle & I was extremely happy. I have previously dealt with Yarra Valley Nissan & would never send another car there for repairs ever after having my car returned to me in pieces & with a flat battery.
Thanks heaps for that cuzzo. That will help heaps when sorting this out tomorrow. I'm in the Latrobe Valley. I'll let you know how I go.
