I am a NEW member. Can't seem to figue out how to download GU manual.
I need to know how to adjust headlight beam height
Post an intro Dr then 24 more posts and away ya go. Just don't post cr@p or the mods will shut ya down. Good luck and welcome aboard gotta friendl mob here full of great info and advice
hi mate, Do I need to post an intro every time I get on to get some feedback?
There's plenty of people here who are great help! Not been here long, but hope I'll be able to help out one day with Patrols!
I might be able to help out with any machinining questions (Lathe/Mills etc) though it has been 4 or 5 years since I used one!!!! So I might be a bit rusty but these things come back to me! :)
Just bought new keys for my GU and am over 200 km from a dealer to get them programmed. How can I start the engine to drive the car there for programming?
It will be easier for you to see the beams of each light as you adjust them if you cover the light you are not adjusting with a blanket or similar item which will block out the light beam. Be careful not to use something which will melt or burn!
hi everyone . i am a new member. i have a clutch cylinder promblem and need some advice. thanks .
Once you've got 25 posts that aren't cr@p then the manuals are yours mate. Alternitavely find the section relating to your problem and ask away heaps of helpful peeps here
Tappin N Crappin
