I have read the "What to keep my eye on? Preventative Maintenance" nothing yet on greasing
I am unable to find any grease nipples on the GU y61
this is very different to the MQ
As far I know they only on the front and rear driveshaft joints.
Hi Lenkiet1234.
There should be one on each tailshaft slip joints plus one on each u joint.
Do not over grease any of these points,one or two pumps of the gun is enough.
over greasing of the tail shaft can cause the welch plug in the shaft to be pushed out and the grease thenfills the tail haft.
Thanks guys I am a little surprised that that is the extent of greasing a 4wd
How are the front hubs lubricated
The front hubs are factory greased and would only be re greased if you had a bearing repack as per service manual intervals.
Not sure of interval period. If you have grease leaking out at the hub you will have to service it and replace the seals. On Patrols these hubs give very little trouble.
i
I am sure that the intervals will be in the service manual
Make sure you keep an eye on the servicing intervals for the front wheel bearings. Missed mine and shortly after they let go. Not a cheap exercise
Cheers Guido
Must be due its at 300k and not much taken care of on the poor girl
so u dont grease tie-rod ends like in a gq
So if i have read this correctly there is only 6 grease nipples spots for a GQ?
Two on each tailshaft slip joints (4) and plus one on each u joint (2)
