Clutch slipping, what to do?
Hi guys, I'm away at the moment visiting olds on tappa so hard to type.
I noticed when under load changing from 3rd to 4th to power up hills and at around 2.1k revs as soon as you drop it in 4th and power up slightly it sometimes jumps up and down a bit so I'm guessing the clutch is slipping a bit under load.
That's the only time it happens. My question is what do you guys recommend?
Have I got a long time before it's an issue, is it worth the risk?
I drop clutch in first with handbrake on and stalled straight away but not sure if that's the best test or not.
Any recommendations on a type of new clutch too?
Little bit concerned about our trip coming up in a few weeks too.
Cheers for any advice!
