Well the reason for the gearbox rebuild was due to loosing everything above 2nd gear.
Manuals / Part breakdowns that I used can be found here: http://www.nissanpatrol.com.au/forum...851#post143851
Cost to repair
Gearbox
Master Rebuild Kit - $643.00
RE4R03A Gasket, Seals & Ring Kit
Band
Oil Filter
Full Set Of Clutch Frictions
Pump Brush
Change Over J6 Torque Convertor - $395.00
Refundable Deposit on Torque Convertor - $250.00
Freight - $60.00
Total: $1348.00
Automatic Transmission Fluid
Syntrans SYN III G/H 10W 20LTR - $125.40
Total: $125.40
Consumables
Emery cloth GP 180 grit x 50mm ( 50mtr roll ) - $34.53
Lanotec Citra-Force 750ml spray bottle x 2 ( wanted 1LTR but nobody local had stock - $ 36.37
Wet-Dry Sheet 9 x 11, 120 grit x 6 - $6.02
Total: $76.93
Total Cost Of Rebuild to Date - $1550.33 including GST
Rebuild Kit and Convertor supplied by:
Wholesale Automatic Transmissions
1/58 Barry Street
Bayswater, VIC, 3153, Australia
03 9762 8108
Consumables supplied by:
Nepean Boltmaster - Penrith Branch
42 Borec Road
Penrith, NSW, 2750, Australia
02 4722 3034
Automatic Transmission Fluid supplied by:
Gulf Western Premium Quality Lubricating Oil ( Aust )
1 Coombes Drive
Penrith, NSW, 2747, Australia
Phone: 61 2 4732 3305
Sales: 1800 248 919
Rebuild Kit has arrived :)
Attachment 7775Attachment 7776Attachment 7777Attachment 7774
20ltr of ATF
Attachment 7823
Emery cloth, Wet-Dry sheets, Lanotec Citra-Force
Attachment 7824
Tags:
Auto gearbox failure
