Thinking of getting a turbo fitted to my TD42. not sure weather its worth the money, more to the point, if i put a set of extractors and a 2 and a half inch exhaust system, will i notice a change in power???
Theres a few threads on here specifically for that topic mate - I'm on tapatalk, so can't cut and paste the link (someone else may be able to), but if you search TD42 and turbo, you should find a fair amount of information.
Good luck with it mate.
Hi Mike,
I just put a second hand GU turbo to my GQ TD42 and after it got professionally tuned I highly recommend it mate!!!
Below is a link to more info about it...
http://www.nissanpatrol.com.au/forum...-to-a-N-A-TD42
The way I see it, a turbo manifold will probably cost the same as extractors and then all the extras you need are a turbo, oil lines and the intake side, you were going to get the exhaust done anyway so its not a whole lot more coin to get it turboed. You should be able to pick up a ht18 for bugger all, they're $795 brand new delivered off ebay.
Extractors will do stuff all by themselves, these engines need to be force fed :)
Edit
If you are looking for a used turbo, td42ti models are oil cooled only, td42t models were oil and water cooled.
An oil cooled only turbo will be easier to install
I would go turbo. CI engines don't react as well as SI engines to extractors because of the higher compression ratio. So back pressure around the port isn't as much as a problem in CI as it is in SI engines. After driving a TD42 with 2.5 exh & extractors & a snorkel I couldn't tell any difference to that of my old N/A stock manifold/exh Patrol.
I hear all sorts of stories about how adding extractors adds another gear or it nearly go's as-well as my mates turbo'd patrol etc bullsh@t. I think there would be gains. But so minimal it's not noticeable. Now turbo, that you will notice.
Cheers jono.
I give in, what's an extractor?
Ah gotchya, a bit like this then
http://www.ebay.co.uk/itm/3005821693...84.m1423.l2649
What sort of money are they down under? :xxxx:
I've been using that turbo manifold pic for my mate to make one up for me. I'm going down the turbo route soon ;)
I've just got a bit more work to do on my current 4x4 Nissan Terrano then I'll be full tilt on the Patrol. Taken hundreds of pics as I built the Terrano and will do the same for the Patrol don't you worry ;)
I would go for turbo too,its a different fun,as said,it need to be forced..go for turbo and you wil be hapy
Hi Tony!
I would like to know if this header is for a trol? Thanks buddy.
wouldnt bother with extractors, just spend the money and put a turbo on it most aftermarket kits are around the 2500-3000k mark to buy and the gains speak for them selfs
