mudski
Don’t go to Aussie Desert. I had one of their radiators, had issues and they weren’t keen on helping. I did hear they were like this from others also.
I then went a full triple core copper radiator. Was ok but fatter than the oem core and things were a bit tight. I then bought an aftermarket copy of the original. Worked fine until til the lower hose split due to the lower fitting being 20mm longer that standard so the hose was just rubbing against the a/c compressor.
So now I have a Nissan radiator back in and have zero issues.
The Jayrad radiators are about as close you will get to original too.
FYI, none of the radiators cooled better that each other too. Trust me, my kettle tested them all out. In the end. Original is the best.
