Need to build a half wall/ fence need some ideas…
…on starting it.
I have to get a half wall/ barrier/ fence whatever built at the end of my paving. I know what I want just how to start it has got me puzzled.
http://www.nissanpatrol.com.au/forum...2022/10/16.jpg
The design I have in my head is to use four upright posts, Cypress 90mm square, two at either end then two in the centre evenly spaced, run timber long ways to connect all four, then a wide length of timber along the top, say 150mm wide or so. Then use Colourbond steel paneling to fill in the gap.
My issue is how to mount the posts. I’m thinking using these…
http://www.nissanpatrol.com.au/forum...2022/10/17.jpg
But how to bolt them down without damaging the concrete sleeper and sandstone paving, being so close to the edge.
http://www.nissanpatrol.com.au/forum...2022/10/18.jpg
Any ideas?
Thanks.
So after some contemplation and talking with a mate of mine who makes steel fences and gates etc I have come up with this prototype bracket. It will be welded vertically to the H post, then a hole drilled into the top of the sleeper and a piece of thread rod chemset into the sleeper. Then bolted to either side of the bracket.
Now to make four or them. My little 135amp mig is not up to this so I’ll prep the pieces up and my mate is going to weld them up for me.
http://www.nissanpatrol.com.au/forum...2022/11/55.jpg
