2 Attachment(s)
Size comparison with an LC105
I am honestly still unsure if it is about the size of the LC105 or smaller. It seems about the same size externally but I have a feeling it is smaller inside, both cabin space and trunk size.
Side by side with my friends 105, it looks kind of same size, despite the bike tires.
Attachment 85768 Attachment 85769
9 Attachment(s)
Faded sunburnt paint cut and polish
Paint was very faded like you would expect from a car that mostly never sat under a shade over its life. When I got my 105 it was on the same situation and several friends vouched for a guy that did this for a living, on site. The guy´s work was top notch, very well worth the money, so this time it would not be different, called him to give the GU the head-turning look that it deserved.
Attachment 85808 Attachment 85809
It amazed me how beautiful the tail lights are up close
Attachment 85810 Attachment 85811 Attachment 85812
Attachment 85813
And the foggy/cloudy/opaque headlights transformation was the best part
Attachment 85814
Attachment 85815
Attachment 85816
He is also going to give the first polish to the GQ when I´m ready for that.
4 Attachment(s)
Front wheel bearing adjusting
When I took the GU to the tire shop for mounting, balancing and alignment, the later was not possible to be done due to both front wheels having play on the bearings. So I searched through the forum for instructions and found this great and well illustrated topic by MudRunnerTD:
DIY Wheel Bearing Adjustment
Basically lifting the front wheels up and undoing the (locked) free-wheel hub.
Attachment 85870
By the non marked face of the phillips locking screws on the locking washer, this was the very first time this was taken apart.
Attachment 85871
Used the locking washer to template for a tool creation at a later time.
Attachment 85872
Tension/load nut fastened just one click with a punch (for the lack of the proper tool) and it was done. Just put everything back and its done. Very easy once confident from reading the DIY instructions from the forum.
Attachment 85873
11 Attachment(s)
Right door power lock interesting issue
Driving the GU the other day I noticed that when locking all doors from the drivers door (left for me) central locking, the passenger door (right for me) would toggle the chromed lock inside but the door could still be opened from the outside. Only way for it to really lock the right door was locking it from the outside with the key. Further investigation showed me that either manually or through the the central lock, the right door chromed lock would move to "close to the end" position but you could still press it a bit more and it would move a bit further, just like it had two stages. Sometimes pushing it to the very end would make the door really lock, sometimes not.,
This weekend I have finally disassembled the door and locks to investigate and repair it.
Attachment 86139
For anyone looking to disassemble the GU4 door, this one and a half minute video fair dinkum:
https://www.youtube.com/watch?v=tAsJzSQ3wdg&list=WL&index=2
After removing the dust cover, following the chrome lock, you can see that the lock's left-right movement goes into this boomerang lever that redirects it into up-down movement and then to the the actual lock.
Attachment 86140
And down to the actual lock it goes:
Attachment 86141
This is the lock mechanism together with the servo motor actuator. These are held together by only two screw.
Attachment 86142
Gave the lock a good clean because that usually solves 90% of the issues, but this one was on the other 10% :clownredpuff: Further examining it, I noticed that there was a gap between the metal plate and the plastic body around the area of one locating pin.
Attachment 86143
Closing the gap with hand pressure and cycling the lever a couple of times would make a clock spring click into position and further cycles would work perfectly. Releasing the pressure would allow the gap to form and such clock spring would pop out of position.
Attachment 86144
The locating pin:
Attachment 86145
The solution was to drill through the locating pin and passing a screw through it, to get rid of the gap.
Attachment 86146
Attachment 86147
Attachment 86148
Attachment 86149
Works perfect now!
4 Attachment(s)
Dashboard re-upholstering
The dashboard had already suffered the infamous bubbling issue and was wrapped in vinyl by the previous owner. The wrapping didn't resist the sun and shrunk a lot.
Attachment 86266
Attachment 86268
Attachment 86267
Attachment 86269
I have used the instructions on the following YT video to disassemble the dash. This is absolute gold for anyone attempting this.
https://www.youtube.com/watch?v=_KbVeS7KyW0
6 Attachment(s)
Dashboard removal - center section
The starting point is the stereo/HVAC surrounding. There are two screws (red squares) and 6 plastic tabs. It is actually very easy to remove, prying around it with a plastic pry bar. I highly recommend using only plastic tools for all the prying involved as flat screw drivers and metal pry tools will definitely hurt the part being removed. Once the surrounding is out, disconnect all the plugs from the switches and controls you may have on yours. Next step would be removing the stereo, just 4 screws readily visible and the plugs on its back. I had mine already removed on the picture as I am trying to sort out some issues with it.
Attachment 86270
Attachment 86271
Next, move to the center vents and the mini-glove-box. There are only these 3 screws visible on the front (I pointed out only two to avoid using the middle finger, I am a very polite lad LOL). Then, work around it with plastic pry bars and it comes out as a single piece.
Attachment 86272
Attachment 86273
Attachment 86274
Next, the HVAC panel. Remove the four screws visible on the front and depress both tabs (red arrows) and press the HVAC panel just a little towards the firewall. The HVAC panel does not need to be removed and will stay on the car. The pressing is just to keep it clear from the dashboard when its time to pull it out.
Attachment 86275
19 Attachment(s)
Dashboard removal - glove box side
My GU is LHD, so the glove box is on the left side, but the screws and tabs are exactly on the same position (although mirrored). You see, I used as a reference a video from an RHD GU, and I can say it is exactly the same (mirrored).
Lets start with the glove box itself. With the lid closed, remove the two screws on the bottom. Open the lid and remove the four screws on the top and one on the side. Pull it gently and it will come out as a single piece.
Attachment 86276
Attachment 86277
Attachment 86278
Attachment 86279
Onto the A-pillar: for the handle pry the two screw covers with a plastic tool and remove the two screws to remove the handle. Partially remove the weather strip, in the area from roof to floor. To remove the A-pillar cover, pull it outwards gently and once it pops out of the clips, pull it upwards gently. This revealed the coax cable to the roof aerial that came in my GU.
Attachment 86280 Attachment 86281 Attachment 86282
Onto the vents: remove the screw on the bottom of the silver lower vent cover. Remove the nut that secures the dash lower end. Tuck your head under the dash and remove the screw that secures the lower vent piece from behind. I suggest a short screwdriver for this, as it is a very tight space.
Attachment 86284 Attachment 86283
Attachment 86285
For the lower vent part to come out, some wiggling is necessary. Wiggling alone didn't work for me, though. I had also to tuck my hand under the dash around the lower vent piece to help depressing the metal tabs seen on the picture.
Attachment 86286 Attachment 86287 Attachment 86288
Upper vent was easy, just some prying with the plastic tool and some wiggling. There is a small tab on the top of it that can be reached from the front, but mine came out without fooling with it.
Attachment 86289 Attachment 86290 Attachment 86291
And the last part of the glove box side is the air-bag anchor bolt and its electrical plug. FIRST OF ALL, DISCONNECT THE BATTERY!
Remove the anchor bolt and unplug the yellow plug. I had a hard time figuring out where the latch for the yellow plug was. That is all it takes for the air-bag for now as it will stay bolted to the dashboard and will come out with it.
Attachment 86292
Attachment 86293
Attachment 86294
