5 Attachment(s)
Handbrake/Parking brake solution
As my street is slanted and I live on the top of the hill, even without an working engine, a handbrake was on the top of the list of things to be fixed. With no Patrol reposition parts in my country, I am committed to use all the local resources I have available before importing parts.
Looking at the service manuals and at internet pictures of the handbrake cable, I decided that it was no big deal to build one. With the correct length, correct terminals and same steel cable diameter, it should be not that different from a reposition part.
I disassembled the handbrake drum on the end of the transfer case to take out the original handbrake cable conduit and found the remaining tip of the cable.
Attachment 83543
With that at hand, I went to parts stores to search for a handbrake cable that had the same steel cable diameter, a length longer the the conduit I had, and with one eye connector already crimped on one of the ends. And I found this, the handbrake cable for a 1991 Fiat Uno, eye connectors on both ends and 2.8 meters long. I can actually make two handbrake cables with this and keep one as a spare.
Attachment 83544
Attachment 83545
To do something faster then try and error to find the proper length to cut the cable, I printed the best picture I could find online that showed the complete cable unit and took measurements of that print and my existing cable conduit, to calculate a conversion factor between the printed image and the real part. With that, I have estimated the length of cable that should be left at both ends.
Attachment 83546
Then it was time for the crimped fork holder at the parking brake drum end of the cable. After searching around for cable companies to crimp something similar to me, I didn't like the options I found. Only aluminium cable stoppers could be crimped, the smallest one was a bit bigger then the holes it had to go through to be installed inside the drum, and it didn't seem strong enough for me. I then drilled a hole in a steel solid bar I had laying around, drilled a countersunk drill on one of the ends, cut it to length and used it as my cable stopper. I have passed the cable through that steel stopper, untangled the end of the cable a bit to make it larger then the hole and welded the hole shut with some brazing material. Handbrake is working like a charm!
Attachment 83547
10 Attachment(s)
Finally a TRUE wash, with proper products/chemicals
Well, this has actually done when the car came back from the shop with the rebuilt engine, but since we're talking about car wash, here it is...
Took it to a car washer to finally get rid of all that iron ore crust on the undercarriage. The results were amazing.
Original frame powder coat looks top notch except from minor dots here and there (where hit by debris and small rocks) and on the front right bellow the master cylinder, due to most probably to break fluid leak when someone adapted a different booster and master cylinder.
Attachment 83562
Attachment 83559
That OEM Carlsonic muffler looks so new on a 23 y.o. car that makes me wonder whether it is just galvanized or maybe stainless...
Attachment 83560
Attachment 83561
Attachment 83558
Here you can see my frame is missing a bracket for the stabilizer connection rod.
Attachment 83563
Also noticed that I am missing one clutch lever rubber boot.
Attachment 83564
I can already admire the beautiful body lines with pride!
Attachment 83566
Attachment 83567
Attachment 83565
6 Attachment(s)
Engine at the machine shop
With the engine at the machine shop, I was getting ready for the shopping list. From the mechanic I already knew I needed to provide him a battery and engine mounts and he also asked me to try to either find a new radiator or build a custom one.
Don't know how it is in Australia, but here batteries are quite expensive. I figured out it would take a long time for this restoration to happen, either for engine rebuilt or for body work, so I bought a smaller amp battery.
Attachment 83583
Took the radiator to a big radiator company in my town, where they have also a factory, to see if by any chance they made it for export, since this car was not sold here. They didn't, but the guy took a look and told me that my radiator seemed good, and offered to give it a inside-out acid bath to evaluate the situation. A couple days later he called me and my radiator was like new. Due to excitement I forgot to take a head-on picture of it, but I have these few of it inside the dirty trunk. I guess you can get an idea of how clean it got.
Attachment 83585 Attachment 83584
Engine mounts were sourced from a neighbor country.
Attachment 83586 Attachment 83587 Attachment 83588
17 Attachment(s)
Good news from the machine shop!
Got a call from the machine shop and the news couldn't be better. Engine was in great condition! Sleeves/liners obviously had to be replaced, but engine block was perfect, head was perfect, water pump seemed to be replaced already, oil pump was in perfect condition and the crankshaft after polishing was still STD! The guy was impressed with the engine (first time he saw a TD42) and told me it was very robust.
Look at this beauty!! This is pure porn!!
Attachment 83589
So, machine shop shopping list was all the basics: sleeves/liners, pistons, rings, rod bearings, crankshaft bearings, filters, seals, gaskets. In another lucky strike, I discovered that the TD42 was used in a Komatsu forklift sold here. I could find liners, pistons and rings right out of the shelf! Jackpot! Also, I got to learn that the TD42 sleeves/liners were the same of the TD27, which existed here in the Nissan D21 minitrucks.
Sleves/Liners
Attachment 83592 Attachment 83590
Attachment 83591
Pistons
Attachment 83593 Attachment 83594
Rings
Attachment 83596 Attachment 83595
Attachment 83598 Attachment 83597
Attachment 83599
Engine bearings
Attachment 83600 Attachment 83601
Attachment 83602
Rod bearings
Attachment 83604 Attachment 83603 Attachment 83605
3 Attachment(s)
Some teaser shots from the machine shop
6 Attachment(s)
Some more engine bay miscelaneous
I forgot what for I bought this ball bearing, I believe it was for a belt tensioner pulley.
Attachment 83620
Build a battery tie-down for my new battery. I used a piece of threaded rod and a piece of galvanized angle iron I had laying around.
Attachment 83621
Attachment 83622
Attachment 83623
Attachment 83624
I have also bought these quick disconnects. This is what is saving this battery so far, as I am firing the engine maybe once a month for the last 10 months.
Attachment 83625
