8 Attachment(s)
		T-Ruckus rebuilt modified 2005 Y61 GU 6.5L intercooled turbo ST wagon
		Hi Folks, as suggested in my intro topic Here is Truckus.
(T-ruckus is my dads nick name for him as he reckons is big like dinosaur T rex and makes a ruckus and Truckus sort of rhymes with Truck...so I can kind of follow his logic, but he is a sharp 80 years old, so I will go with that logic)
OK So we start with a 2005 ST wagon TD42Ti sourced as best available at the time in WA in 2020.
Off to Brunswick Diesel https://www.brunswickdiesels.com.au/engine-conversion for engine upgrade for fitting of the brand-new Chevrolet 6500 Optimizer inter cooled turbo ,plumbing, adapters, electrical and new custom built all alloy extreme duty radiator. New Stainless steel Axis Fab snorkel fitted and plumbed in
While that was happening, both diffs service and reco as was the Gearbox and TX case, and install or the ARB compressor, air receivers and diff lockers.
Once that was done, vehicle was carted over to NSW for further fit out.
Add on Superior engineering 4 Inch lift kit https://www.superiorengineering.com....on-wagon-28457 with 2,0 Remote reservoir Fox shocks, Superior ENG Drop box and bush upgrades. Then off to the tire shop for some 16 inch rims (16x8 with offset-26 Dynamics with bead locker imo) and some 315/75r16LT Maxxis Razrs MT tires
https://www.tyrepower.com.au/tyres/m...ctcode=1675325
and bead lockers.
Once Fatboy sliders,  Kaymar bars & carriers, Rhino racks, spots and bar lights, as well as 12000lbs remote winch all installed, off to the engineers to sign off on all mods for mods, conversion cross over signatory from WA, Blue slip and rego from interstate and then all the rego costs.
On from there it was then a trip to Drifta for the install and fit out of the pull out kitchen,  https://www.drifta.com.au/wagon-4-ki...-drawer-table/
and install and  set up duel batteries and 12 V swbd fit out https://www.drifta.com.au/12v/ and add 80 l removable water tank that bolt in behind the rear seat cabinet void, and the Clearview Easy slide ES 150 https://www.clearviewaccessories.com...ew-easy-slide/ for the fridge.
Now after all this was done, it was time to sort out the alignment  pull to the left issue and intermittent wobbles, so this a combo off the LHS front throwing off a 90 weight, and also the need for an offset trunnion, shims and king pin kit that evidently is required with significant lift for my model wagon set up, to get the ability to get an alignment suitable for Aus road camber.
Anyhow, I know a little bit about suspension, but the lads at Big wheels truck alignment Gosford are experts so if they reckon it would sort the problem , I was all ears...and true to their word it did...and he drives straight as a bullet now, one finger on the wheel, no pull, wobble or vibration at all, and actual improved feedback and handling when cornering...so while pricey (1900 with all that work, balancing and alignment done and bloody GST...well worth it).
The vehicle also has the SME UHF set up (came with the vehicle and android plug and play headset gadget and sub woofer under passenger seat). The other stuff is basically tools recovery gear, crash pad dirty gear bag, hi lift jack, wind deflectors and bonnet deflector cosmetics.
I probably have forgotten stuff, but this was a brief summary with some links for those interested in looking at similar options for their rigs, and I wanted the post to read as friendly, not having a wank or anything like that in today's easily offended world. So hope no one was offended as none was intended.
Time for pics to start with I guess.
Attachment 82892Attachment 82893Attachment 82894Attachment 82895Attachment 82896Attachment 82897Attachment 82968Attachment 82969
Oh yep..PS fun stickers
https://www.patrolhub.com.au/collect...w-banner-small
https://www.ebay.com.au/itm/Jims-Rec....c100752.m1982
		3 Attachment(s)
		Next update Repair option 3 New long block
		So now the hand goes deeply into the pocket, and things start to move along again at great pace.
This ships out from Brunswick next Tuesday for arrival a week later up in Blackheath for Install.
Attachment 83337Attachment 83338Attachment 83339
Included is full gasket kit for install, new thermostats and belts, 36 months warranty or 60000 kms and a deal to split the install cost with a negotiated engine discount (as per agreement with Greg at Brunswick I am not at liberty to discuss funds at this time, but the discount was substantial as will be the install cost offset).
Blackheath now will remove all the good bits from my engine and transplant onto the new long block, (so turbo, inter cooler, plumbing, injection pump, lines and injectors, etc) and then return ship exchange my old engine (I believe this cost will be on Bruswicks freight ticket), then install, add fluids, time, tune and test, plus do the paperwork for new engine number certification for NSW requirements.
Fortunately, as the previous engine was already engineered in NSW (in addition to the other mods on the rig) It does not need re engineering , just eng # inspection and certification for the RMS records.
Now option one, glaze break and rehone was discounted as cylinder bore damage was too significant with rust pitting.
Option 2 20 thou over rebore and rebuild with 20 thou over pistons, while an option was going to have a lead time of 6 to 8 weeks due to machine shop back log, and then it was likely I would be also up for new heads as well, and the cost was a few grand more than a replacement  "new" long block was going to be. Truck has already been gone over a month now, and off road for near on two months all ready, so option 3 was the alternative to get things moving.
Now I still got costs with Black heath to pay once the jobs done, for some extra work I got them to do, just on my dime, and the removal and install that Brunswick is splitting with me, so probably a few more grand yet to be spent.
That said....some thing interesting I learnt ...that the bloke who sold me this defect will learn after all costs are known, itemized and rig is up and running again...have a read of lawyer TimW posts on this link https://www.lawanswers.com.au/thread...r-beware.1824/ and expand the initial letter of demand in the first post, from fella who did the same as the bloke who sold me truckus did.
Now if the plaintiff...me ...can show that the seller  "engaged in misleading and deceptive conduct to obtain a financial advantage."
So basically...it is a matter for one party (a plaintiff, such as dissatisfied private car buyer)
to show, on the balance of probabilities, that the other party
(a defendant, such as a private car seller) acted fraudulently when entering into the contract.
But that is very do-able - because proving a negative is quite difficult for a defendant to do.
Now if only the buyer had written evidence that the seller knew about the defect, in addition to written evidence that the defect records on service history was omitted from the service history,  that stat declarations as affidavits confirming the validity of evidence of the defect notification(certified true copy and affidavits reporting failed "CO2 test" and "bubbling its head off" and "head gasket seal additive is a temporary repair solution ONLY") to the seller 6 weeks prior to sale listing, and that the seller has intentionally misrepresented the condition of the vehicle to accept full fair market value of a defect free vehicle as advertised (such as a screen shot of the car sales advert and certified true copy of the listing from carsales records) with the entire description stating "the vehicle is mechanically perfect, under warranty and is capable and reliable enough to take you to cape York or Tuff truck" and at no stage since purchase has admitted to any defect with the vehicle, and  I had detailed service reports showing damage to engine that justified full replacement expense...well...if only I had all those things in evidence....Oh thats right:harhar:...I already have, and yes, I already got a gun commercial law lawyer just waiting the final bill and outcome before pulling the trigger.
Did I mention I love this cruel sea song
https://www.youtube.com/watch?v=RJ0hOKCSuns
As I now feel it is my civic duty to ensure the law teaches this fella a lesson in right and wrong, and reimburses me out of pocket expenses,
Now the best part..as I all ready have certified true evidence, what ever changes this bloke now wants to retrospectively make to any records...well..that will just dig him deeper with fraud...hence why I have no issue in posting about it.
Some interesting learning in this post!
Cheers.
