Hi all. Has anyone out there cut holes into their standard alloy gu 3 bullbar to fit fog lights?
Cheers Alex but you missed the "fog" bit. Have plenty of light coming out the front, but need a bit of low and wide light to go with the low beams to illuminate the edges of the road close by when the weather turns to shyt. Something I can use with oncoming traffic....
Most of the bumper mounted fog lights I am seeing require a square or rectangular hole so drilling might not work.
Hey aren't fog (yellow) lights illegal now??? Driving lights, like those small, normal light, lights usually under the bumper are OK.
A mate told me a trick when cutting ally. Spray WD40, CRC etc where you're going to cut, makes it like a hot knife through butter.
I replaced the "fog/driving" lights on the factory trol steel bar that were quoted as $450+ from Nissan with a $160 pair from Stedi ... OMG the difference .. there is more light from these 2 little suckers than the low beam and it's low and wide .. defo worth a shot. i know what ya mean as well. Tracks, trails and the beach it's nice to have that low and wide spread. I have the big lightbar up top for a bigger field of view but the little fogs work a treat
Guys check Diode Dynamics
